- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey I need some code created please. I will need to use an event trigger on saving the file or when the form is saved or both. I want the selected value for the standard property for both material and appearance to copy to a custom iproperty using illogic. So say the material is steel, then I want this value to be copied to a custom iproperty called gkp_Assembly_Material. Can this be done ? And I want the same for appearance into gkp_Assembly_Apearance. Can someone help please, I’m stuck ! This would neeed to work for ipt and iam files
