@YuhanZhang / @andrewiv ,
Could the code above be adapted to work with a top-level assembly that uses the Parts Only tab instead of the Structured tab? The top-level assembly would contain subassemblies and parts.
After creating a subassembly view, we would like the balloon number (item) of a component to match the item number at the top-level. I appreciate the complexity of this request. I am hoping some code can eliminate the repetitive, manual item number overrides required.
Our current "workaround" is to create multiple views of the top-level assembly and use ViewReps to show just the subassembly we want to document.
Thanks for your time and attention. I look forward to your replies.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
