Mass of weldings
Mass of weldings
Skadborg.NTI
Mass of weldings
Skadborg.NTI
I would like to get the mass of all weldings (actually the total sum is enough for me). Some how this information should be accessible, because the Weld command "Bead Report" writes a spreadsheet like this:
But I can't find this information through the API. The weldings are found in WeldmentComponentDefinition.Welds, but I can't find mass information. I can't even find enough info to calculate them by my self.
Any body got a hint?
bhavik4244
Skadborg.NTI
Thanks a lot
jonathan.victor
Hi, I was searching for the same thing, but didn't find anything <really> helpfull, so i figured it out! Below is a code that will show you the sum of the weld beads in you weldment assembly, with 3 decimal positions, in document units, change the mass unit symbol according to the document unit.
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
oOccs = oDoc.ComponentDefinition.Occurrences
WELD_MASS = Round(oOccs.ItemByName("_WeldBead:1").MassProperties.Mass, 3) & " Kg"
iProperties.Value("Summary", "Comments") = WELD_MASS
MessageBox.Show(WELD_MASS & vbNewLine & vbNewline & "Value copied to Assembly Comments", "There is the value"
Please, mark the answer as solution, if this helps
