Mark feature messes up loop count in iLogic
I am trying to use the Mark feature for the first time. I use an iLogic rule that gets total laser cutting length and number of pierces among other info. When I run my iLogic rule, it gets the distance of one loop of the Mark feature and nothing else. I am not very good at iLogic and am unable to determine why this is happening. I have determined this is directly related to the Mark feature, because if I place the mark on the non-A-Side it is ignored and the correct cutting length and pierce quantity is used. I don't care very much if the mark loops are or are not added to the loop length.
My code is pasted below, and attached is a sheet metal file I'm using it on as an example. Any help is greatly appreciated.
Sub Main
Dim isdoc As Document = ThisDoc.Document
If isdoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Exit Sub
Else
'Create custom iproperties
customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Dim iprop(4) As String
iprop(1) = "Cutting Length"
iprop(2) = "Pierces"
iprop(3) = "Bends"
iprop(4) = "Weight"
For k = 1 To 4
Dim prop(k) As String
Try
prop(k) = iProperties.Value("Custom", iprop(k))
Catch
'Assume error means not found
customPropertySet.Add("", iprop(k))
iProperties.Value("Custom", iprop(k)) = "null"
End Try
Next
'Get cutting length
Dim oSMDoc As PartDocument = ThisApplication.ActiveDocument
Dim oSMDDef As SheetMetalComponentDefinition = oSMDoc.ComponentDefinition
If oSMDDef.HasFlatPattern = False Then
MsgBox("There is no Flat Pattern yet.", vbOKOnly, "NO FLAT PATTERN")
Return
Dim oTopFace As Face = oSMDDef.FlatPattern.TopFace
Dim oMeasureTools As MeasureTools = ThisApplication.MeasureTools
Dim oLoopLength As Double = 0
For Each oEdgeLoop As EdgeLoop In oTopFace.EdgeLoops
oLoopLength = oLoopLength + oMeasureTools.GetLoopLength(oEdgeLoop)
Next
oLoopLength = oLoopLength / 2.54
oLoopLength = Round(oLoopLength, 2)
'get bends
Dim bendqty As Integer = oSMDDef.Bends.Count
'get mass
mass = Round(iProperties.Mass, 2)
'get pierces
TotalPierces = 1
For Each oEdgeLoop In oSMDDef.FlatPattern.TopFace.EdgeLoops
If oEdgeLoop.IsOuterEdgeLoop = False Then
TotalPierces = TotalPierces + 1
Next
'write data to iproperties
iProperties.Value("Custom", "Pierces") = TotalPierces
iProperties.Value("Custom", "Bends") = bendqty
iProperties.Value("Custom", "Cutting Length") = oLoopLength
iProperties.Value("Custom", "Weight") = mass & " LBS."
End Sub
