- Mute
- Permalink
- Report
Hello Inventor experts!
I am here again with other issue to ask you for some help.
I have a situation where a need to measure areas with and without holes from different kinds of surfaces and I am trying to use some ilogic solutions to automate these tasks.
I have got a code some months ago with the colleagues here from forum.
And it’s working perfectly for some specific situation and for other I continue doing manually work and I would like to ask for help to adapt this code to be use in a second situation.
I have attached an ipt file with a prepared scenario to receive the code, and an image with a workflow and details with I imagine will be the solution, in order to help to understand my situation.
Summarizing, there already is a code to extract the area with holes and areas without holes from a surface in an individual way.
And I need help to adapt the code to make a progressive and cumulative sum of several areas.
The code working is in the ipt file in “rule0”.
I am available to provide any other necessary information.
As usual I appreciate all your help and thanks in advance,
