making FX parameter in any part
ekjerside
ekjerside
I need help to make Ilogic that makes fx parameters in any open part just by running the ilogic rule by the user.
Exampel of fx parameters name could be:
Tube_diameter set to 1 mm.
Tube_thickness set to 1 mm.
Length_of_tube set to 1 mm.
Inconel_thickness set 1 mm.
thank you very much....
Frederick_Law
ekjerside
Why not set them in Template? because it maybe not every part that need the parameter....
WCrihfield
Hi @ekjerside.  There are literally tons of variations of code for creating new parameters of various types, in various types of documents, so a quick search of this forum would have resulted in a great many useful posts to review.  Below is just another variation you could use for adding a single numerical UserParameter to a part or assembly.
Dim oDoc As Document = ThisDoc.Document
If oDoc.IsModifiable = False Then Exit Sub
If ThisApplication.FileManager.IsInventorComponent(oDoc.FullFileName) = False Then Exit Sub
Dim oUParams As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
Dim oUParam As UserParameter = Nothing
Dim sParamName As String = "Tube_diameter"
Try
	'Check to see if this Parameter already exists
	oUParam = oUParams.Item(sParamName)
Catch
	'Parameter doesn't exist, so create it
	oUParam = oUParams.AddByExpression(sParamName, "1 mm", UnitsTypeEnum.kMillimeterLengthUnits)
End Try
oDoc.Update
'oDoc.Save
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
ekjerside
I tried this.
Dim sParamName As String = "Tube_thickness"
Dim sParamName As String = "Length_of_tube"
Dim sParamName As String = "Inconel_thickness"
Try
Catch
End Try
oDoc.Update
'oDoc.Save
 But got an error:
Error on Line 7 : Local variable 'sParamName' is already declared in the current block.
Error on Line 8 : Local variable 'sParamName' is already declared in the current block.
Error on Line 9 : Local variable 'sParamName' is already declared in the current block.
what to do?
Frederick_Law
What's wrong with extra parameters in the Template?
I do lots of sheetmetal.  I have all gauge size setup in template which I'll only use one in the part.  Not use if it's not sheetmetal.
I won't run rules to set the gauge I need every time I design a part.
If users need to remember which rules to run for which part, it already failed.
Just my opinion.
WCrihfield
When you need to add multiple parameters at one time, you will need to include a loop to process multiple items.  Here is a very slightly altered version of the earlier rule I posted which includes a loop of those parameter names.
Dim oParamNames As New List(Of String) From {"Tube_diameter", "Tube_thickness", "Length_of_tube", "Inconel_thickness"}
For Each sParamName In oParamNames
	Try
	Catch
	End Try
Next
oDoc.Update
'oDoc.Save
Wesley Crihfield
