Make 2 linear dimension position equal in drawing
tim11_manhhieu
tim11_manhhieu
Hi all,
Is there any solution for this idea, I want to make the 2nd dimension line position 10mm from the 1st dimension line.
The sequence is:
1) Select the 1st baseline
2) Select the 2nd line
Thanks for taking the time.
C_Haines_ENG
This should do the trick:
Dim oView As DrawingView = ThisApplication.CommandManager.Pick(kDrawingViewFilter, "Select Drawing View")
Dim Dim1 As GeneralDimension = ThisApplication.CommandManager.Pick(kDrawingDimensionFilter, "Select First Dimension")
Dim Dim2 As GeneralDimension = ThisApplication.CommandManager.Pick(kDrawingDimensionFilter, "Select Second Dimension")
oPoint = Dim2.Text.Origin.Copy
If Dim1.DimensionLine.Direction.X <> 0 Or Dim1.DimensionType = kHorizontalDimensionType
	If Dim1.Text.Origin.Y > oView.Top
		oPoint.Y = Dim1.Text.Origin.Y + 1
	Else
		oPoint.Y = Dim1.Text.Origin.Y - 1
ElseIf Dim1.DimensionLine.Direction.Y <> 0 Or Dim1.DimensionType = kVerticalDimensionType
	If Dim1.Text.Origin.X > oView.Left
		oPoint.X = Dim1.Text.Origin.X + 1
	Else
		oPoint.X = Dim1.Text.Origin.X - 1
Dim2.Text.Origin = oPoint
Unfortunately you have to select the drawing view because you need to know which side of the drawing the dimension is facing and iLogic gives no easy way to get their attached view.
tim11_manhhieu
you are genius, the code works flawlessly. VBA code for who need.
Option Explicit
Sub AlignDimText()
Set oView = ThisApplication.CommandManager.Pick(kDrawingViewFilter, "Select Drawing View: ")
Set Dim1 = ThisApplication.CommandManager.Pick(kDrawingDimensionFilter, "Select First Dimension (Base): ")
Set Dim2 = ThisApplication.CommandManager.Pick(kDrawingDimensionFilter, "Select Second Dimension: ")
Dim oPoint As Point2d
Set oPoint = Dim2.Text.Origin.Copy
If Dim1.DimensionLine.Direction.x <> 0 Or Dim1.DimensionType = kHorizontalDimensionType Then
    If Dim1.Text.Origin.y > oView.Top Then
        oPoint.y = Dim1.Text.Origin.y + 1
    Else
        oPoint.y = Dim1.Text.Origin.y - 1
Else:
    If Dim1.DimensionLine.Direction.y <> 0 Or Dim1.DimensionType = kVerticalDimensionType Then
        If Dim1.Text.Origin.x > oView.Left Then
            oPoint.x = Dim1.Text.Origin.x + 1
        Else
            oPoint.x = Dim1.Text.Origin.x - 1
End Sub
C_Haines_ENG
Hey I was able to get rid of having to select the view! Was bugging me a lot so I looked a little harder into fixing it. This does only work with Linear Dimensions but that seems to be what you're using anyway.
Dim Dim1 As LinearGeneralDimension = ThisApplication.CommandManager.Pick(kDrawingDimensionFilter, "Select First Dimension")
Dim Dim2 As LinearGeneralDimension = ThisApplication.CommandManager.Pick(kDrawingDimensionFilter, "Select Second Dimension")
	If Dim1.ExtensionLineOne.Direction.Y = 1
	Else
	If Dim1.ExtensionLineOne.Direction.X = 1
	Else
tim11_manhhieu
yes i only use it for linear dimension, i appreciate it.
VBA code below
Option Explicit
Sub AlignDimText2()
    If Dim1.ExtensionLineOne.Direction.y = 1 Then
    Else
Else
        If Dim1.ExtensionLineOne.Direction.x = 1 Then
        Else
End Sub
tim11_manhhieu
I have developed a macro based on the above code, aligning multiple dimension lines. Hope this help.
The sequence is:
1) Scan and select multiple dimension lines
2) Click on the macro
3) Select base dimension
But sometimes an error occurs on line 19, I don't understand much about it, but in short it still works.
Option Explicit
Sub AlignDimension2()
Set Dim1 = ThisApplication.CommandManager.Pick(kDrawingDimensionFilter, "Select Base Dimension: ")
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSelectSet As SelectSet
Set oSelectSet = oDoc.SelectSet
Dim oItem As Object
For Each oItem In oSelectSet
    Set oPoint = oItem.Text.Origin.Copy
    Else
    oItem.Text.Origin = oPoint
Next oItem
oSelectSet.Clear
End Sub
C_Haines_ENG
It's not an iLogic solution, but if you are looking for an easy way to keep a bunch of dimensions aligned with each other you should look into using the "Set" variant of dimensions. For example, the "Chain Set" dimension would be perfect for your application.
Click the down arrow beside the "Chain" dimension and select "Chain Set". Very useful tool and keeps everything organized. Plus if you ever want to add another item in the chain you can right click on the chain dimension and select "Add Member".
