I'm trying to write a rule to retrieve a Custom iProperty value (text) from two parts in an assembly ("side.ipt" and "back.ipt") and store that information into that assembly's User Parameters (Material_Side and Material_Back). This is the code that I have so far.
oOccurrences = ThisDoc.Document.ComponentDefinition.Occurrences 'Get the set of occurrences in this assembly document
For Each oComp As ComponentOccurrence In oOccurrences 'Cycle through each component in the set
oCompName = oComp.Name 'Get the browser name of the component
Try
oCompMaterial = oComp.OccurrencePropertySets.Item("Inventor User Defined Properties").Item("Mat_Name").Value 'Get iProperty value from custom field named "Mat_Name"
Catch
oCompMaterial = "Error"
End Try
If InStr(oCompName, "side") > 0 Then 'Check if the desired bit of text is in the component's name
Material_Side = FormatAsFraction(NomThick_Side) & " " & oCompMaterial 'side material
Else If InStr(oCompName, "back") > 0 Then 'Check if the desired bit of text is in the component's name
Material_Back = FormatAsFraction(NomThick_Back) & " " & oCompMaterial 'back material
Next
As best I can tell the issue is on line 7 as the oCompMaterial value that is returned to me is the catch value "Error" and not the iProperty value of the part. Any suggestions would be appreciated.
Thanks.
