Main assembly activation via vba
k14348
k14348
   i have one main assembly with 200 nos. of sub assemblies. In my browser i will roll down (by 10 rotation of mouse wheel) and edit one of my sub assembly. once i complete my work in sub assembly now i want to activate main assembly by running a macro.
-karthikeyan M
HermJan.Otterman
hello K14348,
you should be able to do that with this code:
' Get the CommandManager object.
Dim oCommandMgr As CommandManager
set oCommandMgr = _inventorApplication.CommandManager
' Get control definition for the line command.
Dim oControlDef As ControlDefinition
Set oControlDef = oCommandMgr.ControlDefinitions.Item("AppReturnTopCmd")
' Execute the command.
Call oControlDef.Execute()
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
k14348
 Thanks for your reply.  Its showing some error. Detail attached in this mail.
Thanq,
karthikeyan M
+91-9894814348
HermJan.Otterman
in the yellow line, replace oDoc with Thisapplication, and than it should work.
so
set oCommandMgr = Thisapplication.CommandManager
the command manager does not belong to the document, but to the application
Herm Jan
