Macros on Start up
Macros on Start up
Macros on Start up
Hi all
How do I automaticaly start a macro that sets up my events when inventor
starts.
The macro below is in my default.ivb file and when I start inventor
I want it to start as well.
Public Sub Setup_events()
On Error Resume Next
'attach to Inventor
Set IvApp = GetObject(, "Inventor.Application")
'if Inventor isn't running, start it
If Err Then
Err.Clear
Set IvApp = CreateObject("Inventor.Application")
IvApp.Visible = True
If IvApp.Documents.Count > 0 Then
Set DocEvents = IvApp.ActiveDocument.DocumentEvents
On Error GoTo 0
Set AppEvents = IvApp.ApplicationEvents
'Set FileAccessEvents = IvApp.FileAccessEvents
Set UserInputEvents = IvApp.CommandManager.UserInputEvents
'etc.......
end sub
We've discussed this before and "I believe" the answer was make it an
add-in. It appears that the default.ivb isn't *really* loaded till you fire
off a sub from it manually or load the VB editor. I had a AutoOpen()
function that I could never get running due to this same issue.
If I'm remembering wrong I'm sure someone will correct me..
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Stuart P" wrote in message
news:E7C5D59C3BCBF537A9645A7DA3EDD58D@in.WebX.maYIadrTaRb...
> Hi all
> starts.
> 'attach to Inventor
> If Err Then
> Err.Clear
> End If
> End If
> On Error GoTo 0
> 'etc.......
> end sub
