get current material of a part
I am able to extract a list of all possible materials in a part with VBA,
but cannot seem to find a way to get the current.
I'd like to assign the name of the current material to a string variable.
Anybody know how to do this?
Jorgen Bjornes
Are you located in the Oslo-area, and need a Mechanical Engineer who really
knows Inventor?
I'm currently available for short-term, long-term or permanent jobs.
See www.bjornes.org for more info and resume (in Norwegian).
Material =
oPropsets.Item("{32853F0F-3444-11d1-9E93-0060B03C1CA6}").ItemByPropId(kMater
ialDesignTrackingProperties).Value
It's in the initalize part of the code I sent you...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"...and quit driving 50MPH in the left lane!!!"
"Jorgen Bjornes" wrote in message
news:oprq067rlympwhjz@localhost...
> Jorgen Bjornes
really
> knows Inventor?
Does this do what you need
Option Explicit
Public Sub getmat()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oComp As ComponentDefinition
Set oComp = oDoc.ComponentDefinition
MsgBox oComp.Material.Name
End Sub
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Jorgen Bjornes" wrote in message news:oprq067rlympwhjz@localhost...
On Thu, 19 Jun 2003 14:18:08 -0700, Sean Dotson" at sdotson dot com
I could not find this small detail. Seemed like you had made some funny
workaround.
But it got late yesterday, so I probably mixed things up.
I'll try again tomight
Thanks, both Kent and Sean.
I'll look into both suggestion, and pick the one I like best 😉
Jorgen Bjornes
www.bjornes.org
