Macro to create shop drawings from Weldment assembly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We are a fabrication company and we do not issue any shop drawings with weld prep details. We just issue GA drawings with lots of views, dimensions and weld symbols that are required for fabrication. The workshop is experienced enough to interpret this drawing without need of shop details.
Now we are expanding and the new workshop needs the shop drawings. So are looking into an option to auto generate shop detail drawings from any particular assembly.
I dont know coding. When needed, i search on the forum any copy it. I didnt find anything close to what i am planning to do.
The ideal workflow would be as follows,
- Create assemblies with frame generator. And some other parts such as gussets, brackets, clamp plates, etc.
- Convert this assembly to weldments.
- Add weld preparations (Weld gaps, chamfers, etc.)
- Run a macro which creates drawing (3 views) of each part in different sheets of single dwg file.
- Then may be manually give dimensions as needed.
I remember few years back i found a macro which created view rep / LOD of each unique part. Not able to find that anymore.
Any help or guidelines on above will be appreciated.
