Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Macro to create hole feature at center of selected face
Message 1 of 9
Hi All,
I am looking for a macro, to create hole feature of 0.5" Diameter at the center of selected faces.
When I run the macro, it should ask for "SELECT FACE" once I select the face/faces, hole of 0.5" Diameter to be created at the center of selected face and should ask for "NEXT FACE" to repeat same operation and "DONE" for terminating the operation.
Please let me know if a code can be written for above mentioned case. Kindly need help from our community's experts on this.
Attached image for your reference.
Thank you..
Harish
Replies (8)
Message 2 of 9
Mark.Lancaster
@Anonymous
Are you looking to automate your steps or can you use this workflow by creating a work point that centers based on a loop of edges?
Then use that point as your starting point for that hole.  If the size of the face changes, the point automatically rec-enters.
Mark Lancaster
Message 3 of 9
Curtis_Waguespack
Hi hmanoharBYAYC,
Here's a quick iLogic macro to do this. Attached is a 2017 example file as well.
I hope this helps.
Curtis
Dim oSheetMetalDoc As PartDocument oSheetMetalDoc = ThisApplication.ActiveEditDocument ' a reference to the component definition. Dim oCompDef As SheetMetalComponentDefinition oCompDef = oSheetMetalDoc.ComponentDefinition ' a reference to the sheet metal features collection. Dim oSheetMetalFeatures As SheetMetalFeatures oSheetMetalFeatures = oCompDef.Features Dim oFace As Face 'Keep Selecting Faces, Hit Esc to finish Do oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select a face") If Not oFace Is Nothing Then Exit Do End If Loop While Not oFace Is Nothing ' Get the outer loop of the face. Dim outerLoop As EdgeLoop For Each outerLoop In oFace.EdgeLoops If outerLoop.IsOuterEdgeLoop Then Exit For End If Next ' Create a workpoint at the edge mid-point Dim oWorkPoint As WorkPoint oWorkPoint = oCompDef.WorkPoints.AddAtCentroid(outerLoop) Dim oPointPlacement As PointHolePlacementDefinition oPointPlacement = oCompDef.Features.HoleFeatures.CreatePointPlacementDefinition(oWorkPoint,oFace) ' Create the hole feature, 0.5 cm dia Call oCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent( _ oPointPlacement, 0.5, kPositiveExtentDirection) 'turn off workpoint oWorkPoint.Visible = False
I hope this helps.
Curtis
Message 4 of 9
Curtis_Waguespack
@Anonymous wrote:
... and should ask for "NEXT FACE" to repeat same operation and "DONE" for terminating the operation.
Hi hmanoharBYAYC,
This version repeats as per your request.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Dim oFace As Face
Do
    oFace = ThisApplication.CommandManager.Pick _
	(SelectionFilterEnum.kAllPlanarEntities, _
	"Select a face, press Esc to finish")
				Exit For
			End If
		Next
		oPointPlacement = oCompDef.Features.HoleFeatures. _
		CreatePointPlacementDefinition (oWorkPoint,oFace)
		Call oCompDef.Features.HoleFeatures. _
		oPointPlacement, 0.5 * 2.54, kPositiveExtentDirection)
		'turn off workpoint
    End If
Message 5 of 9
Hello Sir,
Thank you so much for your response and the ilogic code provided.
Unfortunately the above ilogic code is not working at my end, its showing error:
Error in rule: Rule0, in document: Part3.ipt
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Also i am not able to use the example part file provided, since i am using Inventor-2016 version.
Request you to send me a part file in 2016 version to see the ilogic fulfills my requirement.
As i went through the ilogic code, where i noticed that the center for hole is created by "Work Point". I am looking for an option, where the ilogic should enter into the sketch mode and insert "Point, Center Point" at the center of selected face.
Please help me on this..
Thank you,
Harish
Message 6 of 9
Hello Sir,
Thank you so much for your response.
I am looking for an ilogic and my requirement posted on Mr Curtis post.
Please let me know if you have nay solution.
Thank you Again,
Regards
Harish
Message 7 of 9
S_May
Hi @Anonymous,
I could also make them an ifeature with which you can create the lick and the hole at once (example in the screencast).
If they work a lot with sheet metal there are 100 Solutions.
MFG
Sascha May
Message 8 of 9
Hi Sascha May,
Thank you so much for your response and screencast provided.
The Screecast provided helped me to think in different way to improve my work process.
Problem is, right now we are not suppose to use ifeatures in our project, since these part designs are used globally and we need to set standards to use ifeature, which may happen in later stages.
Please let me know if you know any other  method than this, where center point for hole should be sketch based.
Thanks a lot...
Harish Kumar M
Message 9 of 9
Curtis_Waguespack
Hi hmanoharBYAYC,
I looked at the example I provided in Inventor 2015 and I do see the Unspecified Error in that version. The error seems to be related to creating the workpoint, which you have updated this post to say that you do not want that result.
I think the method for hole placement from linear edges would be the method to use, but unfortunately I do not have the time today to look at this further. Below is that sample in case it helps you or someone else interested in this.
I hope this helps.
Curtis
Hole feature linear placement API Sample
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2018/ENU/Inventor-API/files/Ho...
