Macro to create a revolved part
isocam
isocam
Can anyboy help?
Does anybody have an example macro that can create a new sketch, add a few lines and arcs, Then revolve the sketch around an axis to create a solid part. For example a shaft?
Many thanks in advance!!!
IsoCAM
ekinsb
I was surprised there wasn't a sample in the online help.  Here's a simple one I just wrote.
Public Sub CreateRevolve()
    ' Create a new part.
    Dim partDoc As PartDocument
    Set partDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
                  ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
    Dim partDef As PartComponentDefinition
    Set partDef = partDoc.ComponentDefinition
    ' Create a sketch on the x-y plane.
    Dim sk As PlanarSketch
    Set sk = partDef.Sketches.Add(partDef.WorkPlanes.Item(3))
    Dim tg As TransientGeometry
    Set tg = ThisApplication.TransientGeometry
    ' Draw some geometry.
    Dim points(5) As SketchPoint
    Set points(0) = sk.SketchPoints.Add(tg.CreatePoint2d(0, 0), False)
    Set points(1) = sk.SketchPoints.Add(tg.CreatePoint2d(5, 0), False)
    Set points(2) = sk.SketchPoints.Add(tg.CreatePoint2d(5, 2), False)
    Set points(3) = sk.SketchPoints.Add(tg.CreatePoint2d(4, 2), False)
    Set points(4) = sk.SketchPoints.Add(tg.CreatePoint2d(4, 3), False)
    Set points(5) = sk.SketchPoints.Add(tg.CreatePoint2d(0, 3), False)
    Dim centerLine As SketchLine
    Set centerLine = sk.SketchLines.AddByTwoPoints(points(0), points(1))
    Call sk.SketchLines.AddByTwoPoints(points(1), points(2))
    Call sk.SketchArcs.AddByCenterStartEndPoint(points(3), points(2), points(4))
    Call sk.SketchLines.AddByTwoPoints(points(4), points(5))
    Call sk.SketchLines.AddByTwoPoints(points(5), points(0))
    ' Create a profile from the sketch.
    Dim prof As Profile
    Set prof = sk.Profiles.AddForSolid
    ' Create the revolution.
    Dim rev As RevolveFeature
    Set rev = partDef.Features.RevolveFeatures.AddFull(prof, centerLine, kJoinOperation)
End Sub
Brian Ekins
Mod the Machine blog
jdkriek
Brian, there is a revolve example in help but it's kind of hidden under the Features Object
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
bravaiser
You mention a " example in help" where is such help??? Thank you I am new...
