Macro to Analyse Holes misalignment in assembly
Dear All,
Here is my challenging requirement in Inventor Automation.
Is it possible to create a macro or ilogic to analyse the holes misalignment between the assembled parts.
In details, when we run the macro by selecting the whole assembly or two assembled parts  (like selection we do for "Analyse Interference"), it should read the corresponding hole profiles or hole axis in both the parts with in the give Distance limit (macro should not compare to next set of hole in other part) and should give hole center difference between two parts like the Volume output which we get from "Analyse Interference".
Attached is the example image, where we have a holes misalignment between part "A" & "B" (Shown in BLUE). Macro should compare the distance between the holes in both the part "A" & "B" within the given limit (Circle in BLACK) and give us offset distance value or highlight the misaligned hole ares for visual check.
Request all to give their ides and suggestions for above improvement.
Thank you all...
Harish
Curtis_Waguespack
Hi hmanoharBYAYC,
Macro requests would be better made on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I'll ask the community administrtratror to move this request to that forum.
I hope this helps.
Curtis
