Batch Macro to create flat pattern.
Message 1 of 1
Hi All,
I am looking for a macro, which create flat pattern for all opened sheet metal parts.
Lets explain my requirement in depth:-
Once I open all the required sheet metal parts and run the macro, below mentioned step to be performed:
1. Delete all existing "Flat Pattern" and "A-Side Definition" in active window part, ignore if NO "Flat Pattern" and "A-Side Definition".
2. Macro should ask for select face for "Define A-Side". (Delay/pause for Manual face selection)
3. Once I select the face for A-Side definition, macro should create "Flat Pattern" and execute "Go To Folded Part".
4. Fit the part to screen, orient to standard isometric view, save and close the part (Only Active window part).
5. Active next window part and repeated steps 1 to 4.
6. This cycle (Step 1 to 5) to be performed for all opened parts.
Please let me know if any macro available or can be created, which suits above requirement.
Thank you...
Have a great day..
Harish
Replies (0)
