Here you go from my github rule:
Sub Main()
'user feedback tools start
Dim sw As New Stopwatch()
sw.Start()
'get user input as True or False
Dim Assyboolean As Boolean = InputRadioBox("Turn all Work Features On/Off", "On", "Off", False, "iLogic")
If ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
ToggleParts(ThisApplication.ActiveDocument, Assyboolean)
ElseIf ThisApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
'Dim wfBoolean As Boolean = InputRadioBox("Turn all Work Features & Sketches On/Off", "On", "Off", False, "iLogic")
ToggleAssemblies(ThisApplication.ActiveDocument, Assyboolean)
sw.Stop()
Dim timeElapsed As Timespan = sw.elapsed
messagebox.show("Processing took: " & String.Format("{0:00}:{1:00}:{2:00}.{3:00}",
timeElapsed.Hours,
timeElapsed.Minutes,
timeElapsed.Seconds,
timeElapsed.Milliseconds / 10))
End Sub
Sub ToggleAssemblies(ByVal oAssyDoc As AssemblyDocument, ByVal wfBoolean As Boolean)
'Toggle this document
'set work plane visibility
For Each oWorkPlane In oAssyDoc.ComponentDefinition.WorkPlanes
oWorkPlane.Visible = wfBoolean
Next
'set work axis visibility
For Each oWorkAxis In oAssyDoc.ComponentDefinition.WorkAxes
oWorkAxis.Visible = wfBoolean
Next
'set work point visibility
For Each oWorkPoint In oAssyDoc.ComponentDefinition.WorkPoints
oWorkPoint.Visible = wfBoolean
Next
'Check all referenced docs
Dim oDoc As Inventor.Document
For Each oDoc In oAssyDoc.AllReferencedDocuments
If TypeOf oDoc Is partdocument Then
ToggleParts(oDoc, wfBoolean)
Else
For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
Next
For Each oWorkAxis In oDoc.ComponentDefinition.WorkAxes
Next
For Each oWorkPoint In oDoc.ComponentDefinition.WorkPoints
Next
ToggleAssemblies(oDoc, wfBoolean)
Next
'update the files
InventorVb.DocumentUpdate()
End Sub
Sub ToggleParts(ByVal oDoc As document, ByVal wfBoolean As Boolean)
Dim PartDoc As PartDocument = oDoc
''get user input as True or False
' Dim partboolean As Boolean = Nothing
' If wfBoolean = Nothing Then
' partboolean = InputRadioBox("Turn all Work Features On/Off", "On", "Off", False, "iLogic")
' Else
' partboolean = wfBoolean
' End If
For Each oWorkPlane In PartDoc.ComponentDefinition.WorkPlanes
Next
For Each oWorkAxis In PartDoc.ComponentDefinition.WorkAxes
Next
For Each oWorkPoint In PartDoc.ComponentDefinition.WorkPoints
Next
togglePartSketches(oDoc, wfBoolean)
End Sub
Sub togglePartSketches(ByVal doc As document, ByVal wfBoolean As Boolean)
For Each o2DSketch As Sketch In doc.ComponentDefinition.Sketches
o2DSketch.Visible = wfBoolean
Next
For Each o3DSketch As Sketch3D In doc.ComponentDefinition.Sketches3D
o3DSketch.Visible = wfBoolean
Next
'wfBoolean = InputRadioBox("Toggle Sketch Dimension display On/Off", "On", "Off", False, "iLogic")
o2DSketch.DimensionsVisible = wfBoolean
Next
End Sub
This rule also turns off sketches.
