Macro Issue - the object invoked has disconnected from its clients
Hi All,
I have issue with my simple macro that generate pdf or dxf file from the drawing, then Check in drawing to the vault and after that closing the current drawing/document.
PDF or DXF generator code...
'Vault
  Sub CheckInVault()
        ThisApplication.ActiveDocument.Save
            Set ctrdef = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop")
        If Not ctrdef Is Nothing Then
    ctrdef.Execute
End If
End Sub
' Close
  Public Sub CloseIDW()
        Dim IDW As DrawingDocument
        Set IDW = ThisApplication.ActiveDocument
        IDW.Close Save = False
End Sub
'Macro close
Public Sub closeForm()
        Unload ExportFromIDW
End Sub
The code works fine without closing drawing after check in..or with close option but without check in option to the vault . Macro works perfect in debug mode - no errors. If i chose Generate, Check in to vault then close drawing I am getting error after close 'the object invoked has disconnected from its clients' and inventor crash. 😞
I can not find what is causing the iisue beetwen two simple options Check in to the vault and close document.
Any idea?
Just want to add some screenshots
Then when I click debug:
2015-05-05 06_34_42-Microsoft Visual Basic for Applications - WIP.ivb [break] - [ExportIDW (Code)].jpg
And crash:
Code:
2015-05-05 06_37_19-Microsoft Visual Basic for Applications - WIP.ivb - [ExportFromIDW (Code)].jpg
Hi guys I just add line to :
Line added : On Error Resume Next
Sub ExportIDW()
ExportFromIDW.Show
End Sub
It looks like it works ok now. Is that ok?
