macro for copying material
Message 1 of 9
hi,
can someone help me do a macro?
i want to pick the part material in my assy and copy it to a the same assy custom prop.
many thanks
inventor 2013
vault 2013
Replies (8)
Message 2 of 9
augusto.goncalves
I would suggest you start with this blog post: http://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Message 3 of 9
can somebody help me do a simple code to display in msgbox the material of the part ?
thanks
Message 4 of 9
jdkriek
Correct me if I am wrong, you are wanting to be able to click a part inside an Assembly and display the material for that part in a msgbox inside the Assy? And you also want to copy that material to a custom property inside the Assy?
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 5 of 9
yes... thats exactly what i want to do...
is it possible?Smiley Frustrated
Message 6 of 9
jdkriek
Sure anything is possible 😉
I suggest you study the code, it's very simplistic.
Public Sub MatCopy()
'JDK 2013
    On Error Resume Next
    ' Get the Assy Document
    Dim oAssDoc As AssemblyDocument
    Set oAssDoc = ThisApplication.ActiveDocument
    ' Select occurrence
    Dim oOccurrence As ComponentOccurrence
    Set oOccurrence = oAssDoc.SelectSet.Item(1)
        If Err Then
            MsgBox "An occurrence must be selected."
            Err.Clear
            On Error GoTo 0
            Exit Sub
        End If
    ' Define name and material as strings
    sName = oOccurrence.name
    sMat = oOccurrence.Definition.Material.name
    ' Get custom property set
    Dim customPropSet As PropertySet
    Set customPropSet = oAssDoc.PropertySets( _
    "Inventor User Defined Properties")
    ' Add new property with name and material
    Call customPropSet.Add(sMat, sName)
    ' Msg the material
    MsgBox (sName & " = " & sMat)
End Sub
Jonathan D. Kriek
Message 7 of 9
you save my day!!!
thank you so so so much..
what does this code mean? On Error GoTo 0
what is zero?
Message 8 of 9
ive change  sName to some namexxx.
id like to add a code for deleting the namexxx if it exist..
thank you so much  Smiley Happy
Message 9 of 9
jdkriek
On Error GoTo 0 disables any error trapping currently present in the procedure.
Jonathan D. Kriek
