lots and lots of errors caused by dll files
ı had a 1920 error during the installation and I tried to solve by following your description ı deleted and reinstalled c++ visuals of 2008 and 2010 afterward ı removed 2 files( msvcp100.dll msvcr100.dll) but ı had the same error once again but with an option ''ignore'' I clicked it my installation completed and I tried to launch it but ı got a different error called '' VCRUNTIME140.dll can not be found'' ı clicked OK but just got another error called ''MSVCP140.dll can not be found'' ı really don't know what to do ı really need your help. PLEASE HELP ASAP
WCrihfield
What all were you trying to install / reinstall exactly?
Was it working before?
Try searching here in the mean time: https://knowledge.autodesk.com/support/inventor/troubleshooting?sort=score
Wesley Crihfield
(Not an Autodesk Employee)
You need to install the Microsoft Visual C++ 2015 Redistributable Update 3 RC from the link supplied in the marked as answer reply to this thread, the 32bit version download and install of the data link library will be the most likely one that you will need, even if you are using a 64bit system, however, if the app that needs the file to run was developed for a 64bit OS only then you will need the 64bit version. You can install both versions on a 64bit system as a 64bit system will run both 32bit and 64bit apps and/or programs.
Here is the link again, for your convenience.
https://geeksadvice.com/fix-vcruntime140-dll-is-missing-error-on-windows/
