Loop through BOM in assembly and get iProperties using Apprentice
I would like to ask if it is possible to loop through the assembly file using Apprentice Server and export information from BOM (part number, description, . I read everywhere that people can access BOM through Apprentice Server but I never found a working solution how to do it.
I would need Part number, Description, Category, item QTY, Mass, G_L (custom parameter for unit length), Full file Path.
If I reference :
Dim oApprentice As ApprenticeServerComponent
    oApprentice = New ApprenticeServerComponent
    ' Open a document.
    Dim oDoc As ApprenticeServerDocument
    Dim oBom as inventor.bom
    oDoc = oApprentice.Open("filename.iam")
    oBom  = oDoc.componentdefinition.bom     <- This property/method is not available in Apprentice
Can you please help me how to do it correctly.
Thank you.
JelteDeJong
in the documentation i could only find: "Apprentice provides access to file references, assembly structure, B-Rep, geometry, attributes, render styles, and document properties." In the ApprenticeServerDocument object i could also not find any reference to a BOM object (like in the full Inventor api).
But it is possible to acces the assembly structure. therefor you could write your own BOM/List object. something like this:
c# (console application)
class Program
        private static Dictionary<string,BomItem> BOM = new Dictionary<string,BomItem>();
        static void Main(string[] args)
            string fileName = @"C:\temp\Assembly2.iam";
            ApprenticeServerComponent apprentice = new ApprenticeServerComponent();
            ApprenticeServerDocument apprenticeDoc = apprentice.Open(fileName);
            createPartsOnlyBom(apprenticeDoc);
            foreach (KeyValuePair<string, BomItem> item in BOM)
                BomItem b = item.Value;
                Console.WriteLine("{0}|{1}|{2}",b.qty, b.fullFileName,b.partNumber);
            Console.ReadKey();
        public static void createPartsOnlyBom(ApprenticeServerDocument doc)
            foreach (ComponentOccurrence occ in doc.ComponentDefinition.Occurrences)
                if (occ.ReferencedDocumentDescriptor.ReferencedDocumentType == DocumentTypeEnum.kAssemblyDocumentObject)
                    createPartsOnlyBom(occ.ReferencedDocumentDescriptor.ReferencedDocument);
                else
                    if (occ.BOMStructure == BOMStructureEnum.kNormalBOMStructure ||
                    occ.BOMStructure == BOMStructureEnum.kPhantomBOMStructure)
                        string fulldocName = occ.ReferencedDocumentDescriptor.FullDocumentName;
                        if (BOM.ContainsKey(fulldocName) == false)
                            ApprenticeServerDocument docOcc = occ.ReferencedDocumentDescriptor.ReferencedDocument;
                            BomItem newItem = new BomItem();
                            newItem.fullFileName = fulldocName;
                            newItem.qty = 1;
                            newItem.partNumber = docOcc.PropertySets["Design Tracking Properties"]["Part number"].Value;
                            BOM.Add(fulldocName, newItem);
                        else
                            BOM[fulldocName].qty += 1;
    public class BomItem
        public string fullFileName;
        public int qty;
        public string partNumber;
Jelte de Jong
Blog: hjalte.nl - github.com
Thank you very much for your help. I have already used a different solution, i.e. to export BOM to Excel with full file path and then load it into my program, where I reference each file path in the assembly and I use InventorView activeX component to display parts and subassemblies within my program. As I need to do it only once, it is no big deal. But when I have time, I will try your solution too.
