Loop through Assembly for iProperties
haphanthanhtam.work
haphanthanhtam.work
Hi
I need to loop through an assembly and get iProperties for each part. The iProperties i need are:
Length
Width
Hight
How can i do this? I can loop through the assembly but im struggling to get all of the properties.
Below is the code for getting the size:
L1 = Measure.ExtentsLength
L2 = Measure.ExtentsWidth
L3 = Measure.ExtentsHeight
'Sort measurements
L4 = MinOfMany(L1,L2,L3)
L6 = MaxOfMany(L1,L2,L3)
L5 = L1 + L2 + L3 - L4 - L6
'Create external custom parameters
iProperties.Value("custom","Length") = Round(L6)
iProperties.Value("custom","Width") = Round(L5)
iProperties.Value("custom","Hight") = Round(L4)
JelteDeJong
try this:
Sub Main()
    Dim doc As Document = ThisDoc.Document
    For Each refDoc As Document In doc.AllReferencedDocuments
        If (refDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject) Then Continue For
        SetProperty(refDoc)
    Next
End Sub
Private Sub SetProperty(doc As PartDocument)
    Dim box As Box = doc.ComponentDefinition.RangeBox
    Dim L1 As Double = box.MaxPoint.X - box.MinPoint.X
    Dim L2 As Double = box.MaxPoint.Y - box.MinPoint.Y
    Dim L3 As Double = box.MaxPoint.Z - box.MinPoint.Z
    'Sort measurements
    Dim L4 As Double = {L1, L2, L3}.Min()
    Dim L6 As Double = {L1, L2, L3}.Max()
    Dim L5 As Double = L1 + L2 + L3 - L4 - L6
    SetCustomProperty(doc, "Length", L6)
    SetCustomProperty(doc, "Width", L5)
    SetCustomProperty(doc, "Hight", L4)
End Sub
Public Sub SetCustomProperty(doc As PartDocument, name As String, value As Double)
    Dim propSet As PropertySet = doc.PropertySets.Item("Inventor User Defined Properties")
    Try
        propSet.Item(name).Value = value
    Catch ex As Exception
        propSet.Add(value, name)
    End Try
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
haphanthanhtam.work
It's work perfect
Thank you very much !!
haphanthanhtam.work
It's work perfect
Thank you very much
sun069099
Hi:
請問如果要最大值x第二大值x最小值,我該如何實現呢
