Loop "Try" and "Catch" until success.
C_Haines_ENG
Message 1 of 15
C_Haines_ENG
Hello, im trying to write a Try and Catch script that will attempt to rename solidbodies until it succeeds. I am assigning certian solids to become "Duplicates" , thus being named a part number such as 660000_DUPLICATE_1, 660000_DUPLICATE_2 but when it gets to a new duplicate of a new part number I want it to reset back to 1. So as a list it might look something like this
660001
660002
660002_DUPLICATE_1
660002_DUPLICATE_2
660003
660003_DUPLICATE_1
Here is the code, but im not sure how to loop such a command.
Dim SB As SurfaceBody
Dim oDoc As PartDocument = ThisDoc.Document
Dim SBs As SurfaceBodies = oDoc.ComponentDefinition.SurfaceBodies
Dim DupNum As Integer = 1
'CLEAR ALL PREVIOUS NUMBERS
For Each SB In SBs
If InStr(SB.Name,"_") <> 0
	Try
		SB.Name = "DUPLICATE_" & DupNum
	Catch
		DupNum += 1
	End Try
DupNum = 1
Next
 In my mind it would loop until it no longer gets an error.
Replies (14)
Message 2 of 15
WCrihfield
Hi @C_Haines_ENG.  How do you determine which ones will be duplicates?  When you start out, none of the bodies are allowed to have the exact same name, so each name will already be unique.  In that situation, how are you determining which one needs the "_Duplicate_#" after its name?  Do these bodies represent other model files that have been derived into this part, and the name reflects the part number of that derived in model?  If that is the case, I'm gessing it would want naturally create a body named something Solid3, then you would rename it to reflect that model's PN, right?  In a situation like this, I would be tempted to use a separate custom Function, similar to the following.
Function NameUsed(oBodys As SurfaceBodies, sName As String) As Boolean
	If (oBodys Is Nothing OrElse oBodys.Count = 0) Or sName = "" Then Return False
	For Each oBody As SurfaceBody In oBodys
		If oBody.Name = sName Then Return True
	Next
	Return False 'that name was not found
End Function
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 15
C_Haines_ENG
The user will manually enter a "_" character into the solid body name. This tells the program that it is a duplicate and a manual pick is used to select which part number it is a duplicate of. Ive updated my code to better reflect this process.
For Each SB In SBs
If InStr(SB.Name, "_") <> 0
	DupeOF = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select what Solid This Part is a Duplicate of")
	Try
		SB.Name = Left(DupeOF.Name, 6) & "_DUPLICATE_" & DupNum
	Catch
		DupNum += 1
	End Try
DupNum = 1
Next
Message 4 of 15
WCrihfield
Try this.  Just added a fairly generic For loop in there.
Sub Main
	Dim oPDoc As PartDocument = ThisDoc.Document
	Dim SBs As SurfaceBodies = oPDoc.ComponentDefinition.SurfaceBodies
	If SBs.Count = 0 Then Exit Sub
	Dim CM As CommandManager = ThisApplication.CommandManager
	Filter = SelectionFilterEnum.kPartBodyFilter
	Dim i As Integer = 0
	For Each SB As SurfaceBody In SBs
		i = i + 1
		If i = 1 Then Continue For 'skip first body
		If InStr(SB.Name, "_") <> 0 Then
			Dim DupeOF As SurfaceBody = CM.Pick(Filter, "Select what Solid This Part is a Duplicate of")
			If DupeOF Is Nothing Then Continue For
			For DupNum As Integer = 1 To 100
				Try
					Exit For
				Catch
					'do nothing here, and let the DupNum increment naturally
					'otherwise it will throw an error if both try & catch fail
				End Try
			Next 'DupNum
	Next
End Sub
Wesley Crihfield
Message 5 of 15
C_Haines_ENG
Doesnt seem to do anything unfortunately.
It renames the first correctly but does not incriment, I dont understand why.
Message 6 of 15
WCrihfield
Maybe you need to include the current name of the current body within the Pick prompt message, that way you know which one it is referring to, so you know which other one to pick in that situation.  I know these types of situations can be tricky.  When I first posted that last code, I forgot to include the 'Exit For' clause in there, for when the 'Try' part succeeds at renaming the body.  So, I went back and edited that little bit in there.  Otherwise it would rename that body like 90x times.
I'm also thinking that the initial filter might be more accurately changed from:
...to this:
If SB.Name.EndsWith("_") Then
Wesley Crihfield
Message 7 of 15
C_Haines_ENG
I cant seem to get this to work even with the revised code.
It runs once, tries to rename with a value of 1, and then promptly gives up.
Message 8 of 15
Curtis_Waguespack
Hi @C_Haines_ENG
Maybe just a different approach? Something like this:
Dim oCollection As ObjectCollection
oCollection = ThisApplication.TransientObjects.CreateObjectCollection
Dim hSet As HighlightSet = ThisDoc.Document.HighlightSets.Add()
SelectAgain :
While True
	For Each SB In oCollection
		hSet.AddItem(SB)
	Next
	SB = ThisApplication.CommandManager.Pick(
	SelectionFilterEnum.kPartBodyFilter, "Select a set of duplicate bodies ( [press ESC to continue]")
	' If nothing gets selected then we're done
	If IsNothing(SB) Then Exit While
	oCollection.Add(SB)
	If oCollection.Count = 1 Then
		oCollection.Item(1).Name = "$" & Left(oCollection.Item(1).Name, 6)
		InventorVb.DocumentUpdate()
	For i = 2 To oCollection.Count
		oCollection.Item(i).Name = oCollection.Item(1).Name &  i & "_Temp"
	Next
	oCollection.Item(1).Name = Left(oCollection.Item(1).Name, 6+1)
		oCollection.Item(i).Name = oCollection.Item(1).Name & "_DUPLICATE_" & i - 1
	Next
End While
Dim sName As String
For i = 1 To oCollection.Count
	oCollection.Item(i).Name = oCollection.Item(i).Name.Replace("$", "")
Next
hSet.Clear
oCollection.Clear
oInput = MessageBox.Show("Select another set?", "ilogic", MessageBoxButtons.YesNo)
If oInput = vbYes Then
	GoTo SelectAgain
I hope this helps.
Curtis
Message 9 of 15
C_Haines_ENG
While this is a neat solution, im trying to integrate the whole thing into a much much larger script that will also renumber everything. Once it gets to a SB with a "_" it will highlight the panel and you will select what its a copy of.
Is there truly no way of looping the Try command?
Message 10 of 15
Curtis_Waguespack
Hi @C_Haines_ENG
I think maybe Inventor ( or the API) has an internal error check that catches same name solid bodies and handles the error during processing, and that is what is getting in the way if the Catch statement here.
I'll take another look at your original approach, though and see if I can slip in some temp naming to deal with that.
I hope this helps.
Curtis
Message 11 of 15
C_Haines_ENG
I have found the root cause, the "Exit For" loop under the "Try" line STILL RUNS even if the command line above it fails. I have simplified the code to see what exactly whats going wrong and that was infact the problem.
First solid it succeeds, but then it goes to the next one, starts at one, and then counts it as a successfull rename even though it did not rename it at all. Is it because the solid body already exists so it thinks it succeeding in renaming it?
		For DupNum As Integer = 1 To 5
			Try
				MessageBox.Show(DupNum, "Duplicate Number")
				Exit For '<<<< THIS STILL RUNS IF THE LINE FAILS?
			Catch
			End Try
		Next
Next
Message 12 of 15
WCrihfield
Interesting thought.  If (SB.Name = "DUPLICATE_" & DupNum) is True, it will continue to run whatever code is on the next line, so it must be encountering that situation (that body's name is already that name that you are trying to set it as).  You could maybe create a Boolean (inside the loop, so it resets to False each time), then check the body's name 'before' and 'after' the attempt to change it, and if it is different, set the Boolean to True (representing - it changed its name).  And if True, proceed to next body, instead of trying to rename the same body again.  You may need to put a document update in there, just to be sure.  Just some thoughts.
Wesley Crihfield
Message 13 of 15
Curtis_Waguespack
that seems to fit with what I was seeing, with the original example... I think it was not ever getting the Catch statement
Message 14 of 15
C_Haines_ENG
I "fixed" the code?
			Try
				If SB.Name = "DUPLICATE_" & DupNum = True
					MessageBox.Show("True " & DupNum, "Duplicate Number")
					Exit For
				Else
					MessageBox.Show("False " & DupNum, "Duplicate Number")
			Catch
			End Try
		Next
Next
This is absolutely stupid.
Message 15 of 15
Frederick_Law
Do you need the Try-Catch?
How about check
 before
 Fix the problem before the program crash.
