Looking for a IPJ file for 2011 Inventor Viewer (Current Folder ".")
Message 1 of 1
I'm Looking for a IPJ file with the search path set for the Current Folder ".")
As this is for Nothing else but the 2011 Inventor Viewer I would like every other option turned off.
I would create one myself but we do not have Inventor 2011.  Just the viewer
We own Inventor R8 - R10 but that uses simple text based IPJ not xml.
In short I am trying to upgrade an app I created in WinXP that uses the R10 Viewer ActiveX to Windows 7 and the Inventor 2011 Viewer ActiveX.  The viewer is only used to view assemblies and drawings that have been pack & go'ed to a single folder in their entirety, so the IPJ just needs to point to the Pack & Go folder it is found in.
I am also trying to locate code for the 2011 Apprentice to set the IPJ Folder and IPJ Active File.
I believe the accessable objects have changed completely since R10.
Basically I :
. Save the Project folder Path
. Save the Project Acitve File Name
. Set the Profect Folder Path to a new path
. Set the Project Active File Name to a new File Name
. Run the Viewer ActiveX with the new Project File.
. Restore the saved Project pat5
. Restore the saved Active Project File.Name.
I do this in case the user has Inventor R10 on the machine along with my viewer utility
Thanks in advance.
~Tom
Replies (0)
