Locating intersection of plane and edge
llorden4
llorden4
I'm struggling to find a good method to find an intersection of an edge and a plane in a Part file.  I am familiar with using an IntersectWithCurve method, but I've only had success with that feature when using LineSegments.  Since the part shapes can have a very diverse configuration, I'm attempting to avoid having to evaluate every edge just to recreate them as a LineSegement; is that possible to do or is that a step I'm just not allowed to skip, or is there another approach I can take to find these points of intersection?
Here's an example of what I'm attempting to achieve...
Autodesk Inventor Certified Professional
WCrihfield
Hi @llorden4.  I do not really need to use those types of code based tools that often, but another one that comes to mind for that type of situations is the following:
TransientGeometry.SurfaceSurfaceIntersection
...where you could get the 'transient' inputs from WorkPlane.Plane property, and the Face.Geometry property.  I do not recall if I have ever used that one before, but it did come to mind, so I figured it may be worth mentioning.  There are a couple other similar ones under the TransientGeometry object, but they are betting more 3D line/arc oriented, rather than surface oriented.
Wesley Crihfield
(Not an Autodesk Employee)
Curtis_Waguespack
Hi @llorden4
I think this will work.
I hope this helps.
Curtis
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a face.")
Dim oPlane As WorkPlane
oPlane = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Select a work plane.")
Dim oDef As PartComponentDefinition
oDef = oPlane.Parent
Dim oWorkPoint As WorkPoint
Dim oPoint As Point
Dim oIntersectPoints As ObjectsEnumerator
For Each oEdge As Edge In oFace.Edges
	oIntersectPoints = Nothing
	oIntersectPoints = ThisApplication.TransientGeometry.CurveSurfaceIntersection(oEdge.Geometry, oPlane.Plane)
	If oIntersectPoints Is Nothing Then Continue For
	For Each oPoint In oIntersectPoints
		oWorkPoint = oDef.WorkPoints.AddFixed(oPoint)
	Next
Next
Curtis_Waguespack
This seemed useful, so I tailored this to set points at all edges in the part that intersect with the plane. Here's the updated version.
If oPlane Is Nothing Then Exit Sub
Dim oPrefix = "WP_"
For Each oWorkPoint In oDef.WorkPoints
	If oWorkPoint.Name.Contains(oPrefix) Then oWorkPoint.Delete
Next
i = 1
For Each oBody As SurfaceBody In oDef.SurfaceBodies
	For Each oFace As Face In oBody.Faces
			For Each oPoint As Point In oIntersectPoints
				oExists = False
					If oWorkPoint.Point.DistanceTo(oPoint) = 0 Then oExists = True
				Next
				If oExists = True Then Continue For
				oWorkPoint.Name = oPrefix & i
				i = i + 1
			Next 'point
		Next 'edge
	Next 'face
Next 'body
Stakin
I think we should only compare the work points generated by intersections, excluding other predefined work points and system default work points.
For Each oWorkPoint In oDef.WorkPoints(of WorkPoint).Where(Function(oWk) oWk.Name.Contains(oPrefix))
Next
llorden4
There we go, I wasn't too far off and was just missing the ".Geometry" after the oEdge object.
Thanks.
