BOM Export
BOM Export
dsavian
BOM Export
dsavian
Hi there,
I would  like to export the BOM using ILogic, and save automatically the file like an .xls with the same name of the project I'm working on.
Anyone can help me?
llorden4
Perhaps this previously asked question might help?
https://forums.autodesk.com/t5/inventor-programming-ilogic/export-bom-with-ilogic-inventor-2022/td-p...
Autodesk Inventor Certified Professional
dsavian
ok but i need to save the bom file with the same name of the assembly i'm working, automatically, without writing by hand the name.
Dim oFile As String = ThisDoc.FileName(False)
thisBOM.Export("Structured", "oFile.xlsx", kMicrosoftExcelFormat)
Like this but doesnt work
nick5MWHR
Try this:
oPath = ThisDoc.Path
oFileName = ThisDoc.FileName(False) 'without extension
ExcelFileName = oPath & "\" & "RandomText- " & oFileName & ".xlsx"
Mehmet_Fatih_Turker
    Try
        Dim projectDirectoryName As String = GetProjectDirectoryName()
        Dim projectDirectoryPath As String = GetProjectDirectoryPath()
        saveDialog.FileName = projectDirectoryName & " - Replaced Components " & strFileNamePrefix & " to " & OverridedPartNamePrefix & ".xlsx"
        saveDialog.Filter = "Excel Workbook|*.xlsx"
        saveDialog.Title = "Save Excel File"
        saveDialog.InitialDirectory = projectDirectoryPath
        Dim DialogResult As DialogResult = saveDialog.ShowDialog()
        If DialogResult = DialogResult.OK Then
            If Not String.IsNullOrEmpty(saveDialog.FileName) Then
                workbook.SaveAs(saveDialog.FileName)
                MessageBox.Show("Export successful!", "Success", MessageBoxButtons.OK, MessageBoxIcon.Information)
            Else
				MessageBox.Show("Export cancelled or encountered an error.", "Information", MessageBoxButtons.OK, MessageBoxIcon.Information)
	Catch ex As Exception
	   MessageBox.Show("An error occurred while exporting to Excel: {ex.Message}", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
   Finally
        If workbook IsNot Nothing Then workbook.Close(False)
        If excelApp IsNot Nothing Then excelApp.Quit()
        ReleaseObject(worksheet)
        ReleaseObject(workbook)
        ReleaseObject(excelApp)
	End Try
This snippet is the one that I used in order to export custom-created list to excel. Hope it will help. Basicaly;
        saveDialog.Filter = "Excel Workbook|*.xlsx" 'this indicates save as file type
saveDialog.Title = "Save Excel File" 'this indicates save as window title name
saveDialog.InitialDirectory = projectDirectoryPath 'this indicates save path
This part of code does all the work. Hope it will help !
