Hi @bbeilke . This rule must be used in an assembly, it can copy rules and events for mirror parts.
Sub main()
Dim oDoc As Document = ThisDoc.Document
If Not TypeOf oDoc Is AssemblyDocument Then Exit Sub
Dim oAsmDoc As AssemblyDocument = oDoc
Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
If oRefDocs.Count = 0 Then Exit Sub
Dim oDocs As Documents = ThisApplication.Documents
Dim oST As Transaction = ThisApplication.TransactionManager.StartTransaction(oAsmDoc, "CopyRules")
Dim oPBar As Inventor.ProgressBar = ThisApplication.CreateProgressBar(False, oRefDocs.Count, "Copy ryles...")
Dim i As Integer = 1
oPBar.Message = "Loading..."
For Each oRefDoc As Document In oRefDocs
oPBar.Message = "Copy ryles in document. Progress " & i & " of " & oAsmDoc.AllReferencedDocuments.Count & "."
If TypeOf oRefDoc Is PartDocument AndAlso oRefDoc.IsModifiable Then
Dim oPartDoc As PartDocument = oRefDoc
Dim oDrcdComp As DerivedPartComponents = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
If oDrcdComp.Count = 0 Then Continue For
If Not oDrcdComp.Item(1).Definition.Mirror Then Continue For
Dim oDrcdDoc As Document = oDrcdComp.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
Call CopyRules(oDrcdDoc, oPartDoc)
Call CopyEventsPropSet(oDrcdDoc, oPartDoc)
oPartDoc.Save()
End If
oPBar.UpdateProgress()
i += 1
Next
oPBar.Close()
oST.End()
End Sub
Private Function CopyRules(CopyFrom As Document, CopyTo As Document)
Try
For Each oRule As iLogicRule In iLogicVb.Automation.Rules(CopyFrom)
Dim oCopy As iLogicRule = iLogicVb.Automation.AddRule(CopyTo, oRule.Name, "")
oCopy.Text = oRule.Text
Next
Catch : End Try
End Function
Private Function CopyEventsPropSet(CopyFrom As Document, CopyTo As Document)
Dim oPropSet As Inventor.PropertySet = CopyFrom.PropertySets("{2C540830-0723-455E-A8E2-891722EB4C3E}")
Try
CopyTo.PropertySets("{2C540830-0723-455E-A8E2-891722EB4C3E}").Delete()
Catch
End Try
Dim newPropSet As Inventor.PropertySet = CopyTo.PropertySets.Add("_iLogicEventsRules", "{2C540830-0723-455E-A8E2-891722EB4C3E}")
For Each prop As Inventor.Property In oPropSet
newPropSet.Add(prop.Value, prop.Name, prop.PropId)
Next
End Function
