Loading subassembly but instead messagebox
Good evening,
i maar treingebruikers to creatie aan Assembly with ilogic code so i Can switch betweetster 3 subassembly’s which should be loaded after selection of multivalue.
Two of the subassembly’s i copied with copy design. But nog i am trying the code but get a messagebox which Tells me that subassembly’s are uss in anonther project.
how Can i fix this problem?
greetings,
joop
A.Acheson
@Anonymous
Did you solve this problem? That message box usually comes up if the files are not in your active project. Was it ilogic copy design you used or design assistant? The filename should be unique and the file paths should either be in the active project or library files.  Attach some screen shots of the error message box to further investigate the issue.
Regards
Alan
