Loading data from the .xlsx table into the table
ProRuzneDrobnosti
ProRuzneDrobnosti
Hello everyone, is it possible to modify this code (received from FINET_Laurent) so that the data is written to an table (General ProRuzneDrobnosti_0-1708596529886.pngon the Inventor drawing page. Not in Titleblock
Thank you very much for your reply
Sub main
	Dim excelTable As Dictionary(Of String, String) = get_inputs
	Dim doc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
	Dim titleblock As Inventor.TitleBlock = doc.ActiveSheet.TitleBlock
	Dim s As Inventor.DrawingSketch = titleblock.Definition.Sketch
	For Each t As Inventor.TextBox In s.TextBoxes
			For Each k As String In excelTable.Keys
				If t.Text = "<" & k & ">" Then
					titleblock.SetPromptResultText(t, excelTable(k))
					Exit For
			Next
	Next
End Sub
Function get_inputs() As Dictionary(Of String, String)
	Dim propertiesColumn As String = "A"
	Dim valuesColumn As String = "B"
	Dim firstLine As Integer = 1
	Dim lastLine As Integer = 3
	Dim excelTable As New Dictionary(Of String, String)
	For i As Byte = firstLine To lastLine
		Dim p As String = GoExcel.CellValue("TitleBlock.xlsx", "Tabelle1", propertiesColumn & i)
		Dim v As String = GoExcel.CellValue("TitleBlock.xlsx", "Tabelle1", valuesColumn & i)
		excelTable.Add(p, v)
	Next
	GoExcel.Close
	Return excelTable
End Function
A.Acheson
Hi @ProRuzneDrobnosti
Programming/coding questions are best asked in the ilogic/vba forum here.
 The sample you presented is almost unusable for the methods you propose. See this forum sample here. It should need some tweaks to get it working as you need. All that's missing is picking up the values from excel.
Regards
Alan
ProRuzneDrobnosti
Thank you for your answer!
