Linq in Inventor API
taher.basha
taher.basha
Hi Everyone,
I have searched but didn't find any material for "Linq in Inventor API".
I mean how can i use Linq in Inventor API?
any learning link any doc or any block or any other way to learn and implement
I could able to use Linq in Revit API. but, the same couldn't be able to implement in Inventor API.
thanks in Advance
JelteDeJong
In the inventor API most lists do not implement IEnumerable(Of ....). Therefore linq won't work on lists straight from the API. But you can almost always cast to an IEnumerable(Of ....). Here some example:
Dim docs As IEnumerable(Of Document) = ThisApplication.Documents.Cast(Of Document)
Dim fileNames = docs.Where(Function(d) d.FullFileName.Contains(".ipt")).
					Select(Function(d) d.FullFileName)
or if you prefer in C#
IEnumerable<Document> docs = ThisApplication.Documents.Cast<Document>();
var fileNames = docs.Where(d => d.FullFileName.Contains(".ipt")).
                    Select(d => d.FullFileName);
Jelte de Jong
Blog: hjalte.nl - github.com
frederic.vandenplas
Here you have some examples
Dim oDrawDoc as DrawingDocument = thisapplication.activedocument
Dim oSheet as Sheet
= oDrawDoc.Sheets.Cast(Of Sheet).Where(Function(s) s.Name.Contains("MasterDrawing")).FirstOrDefault()
	Dim oDrawingViews As DrawingViews = oSheet.DrawingViews
	Dim oExtView As DrawingView = oDrawingViews.Cast(Of DrawingView).Where(Function(s) s.Name = "EXT.").FirstOrDefault()
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
