How to change a text into upper case in a Drawing File
deffysalfauzi
deffysalfauzi
Question
How to change a text into upper case in this ilogic. example in Project & Part Number in iProperties Model.
Based on this post
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-to-change-sheet-name-in-drawi...
Public Sub Main
	Dim a As Inventor.DrawingDocument = ThisDrawing.Document
	Dim sht As Inventor.Sheet
	Dim shts As Inventor.Sheets
	Dim c2 As Integer = 0
	For Each sht In a.Sheets
		c2=c2+1
		Dim d As Inventor.Document = sht.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
		Dim c1 As String = d.PropertySets.Item(3).Item("Project").Value
		Dim c3 As String = d.PropertySets.Item(3).Item("Part Number").Value
		If c2>0 And c2<10 Then
		sht.Name = c1 & "-" & "00" & c2 & " - " & c3 '& ":" & c2
	ElseIf c2>99 And c2 <1000
		sht.Name = c1 & "-" & "" & c2 & " - " & c3 '& ":" & c2
	ElseIf c2>9 And c2<100
		sht.Name = c1 & "-" & "0" & c2 & " - " & c3 '& ":" & c2
	Next
End Sub
JelteDeJong
Strings have a method ToUpper. I think that is what you are looking for.
Public Sub Main()
		c2 = c2 + 1
		c1.ToUpper()
		c3.ToString()
		If c2 > 0 And c2 < 10 Then
		ElseIf c2 > 99 And c2 < 1000 Then
		ElseIf c2 > 9 And c2 < 100 Then
	Next
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
