link subordinate components
I'm working on an assembly that i can use as a template. i want to be able to control properties of its subordinate components by charging the top level parameters. This all works fine, but i'm figuring a problem is gonna happen when i copy the assembly an change the part names (my assumption is that ilogic will retain the old part names). is there a way to link subordinate components to a parent assembly in a way that will stay linked?
Thanks in advance!
WCrihfield
You can link Parameters between different Inventor documents.
Here are a couple of API samples and another link that would likely be helpful in this case.
One shows you how to link parameters.
The other two are about Parameter Tables / Table Parameters.
Selectively link paramaters API Sample
Table Parameters API Sample
ParameterTable Object
Wesley Crihfield
(Not an Autodesk Employee)
@WCrihfield Thanks for the reply!!
I'm a newbie to ilogic, so forgive me if the answer is there but i missed it.
Here's an example of what i need:
AssemA
CompB
CompC
CompB & CompC have a link to AssemA in ilogic
If I copy AssemA and change the name to AssemA and its components, like such:
AssemA --> AssemD
CompB -->CompE
CompC --> CompF
i want CompE and CompF to keep a link to AssemD in ilogic without having to rename variables.
Is this possible?
