Line + ExtrudeFeatures.AddByDistanceExtent VB.net or vba
i wanna making a extrusion from every select line in Part
/code
Public Sub test()
Dim oPartdoc As PartDocument
Set oPartdoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartdoc.ComponentDefinition
Dim oSelectSet As SelectSet
Set oSelectSet = oPartdoc.SelectSet
If oSelectSet.Count = 0 Then
   Exit sub
end if
    Dim oSketch As PlanarSketch
    Set oSketch = oCompDef.Sketches.item(1)
    Dim oSketchLine As SketchLine
    Set oSketchLine = oSelectSet.item(1)
    Dim oSketch As Sketch
    Set oSketch = oSketchLine.Parent
    Dim oProfile As Profile
 Set oProfile = oSketch.Profiles.AddForSurface
 Dim oCutExtrude As ExtrudeFeature
 Set oCutExtrude = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent(oProfile, 1, PartFeatureExtentDirectionEnum.kSymmetricExtentDirection, PartFeatureOperationEnum.kSurfaceOperation)
end sub
/code
so this code dosent work any one can help me please
thx
xiaodong_liang
Autodesk Support
Autodesk Support
It is not clear to me why you re-defined oSketch. So I just commented out one definition
   ' Dim oSketch As PlanarSketch
   ' Set oSketch = oCompDef.Sketches.Item(1)
    Set oSketchLine = oSelectSet.Item(1)
And I selected any sketch line in one sketch, run your code, the result works fine to me. Please see the attached screenshot.
Best regards,
Xiaodong Liang
Developer Consultant
Autodesk Developer Technical Services
thx for your help because its not working right
create 2 lines select the last create line and start the code
you can see now it makes the extrusion always on the first inserted line 😞 and not on the selected secound line 😞
thx
Mario
I Solved the Problem now with
    Set oProfile = oSketch.Profiles.AddForSurface(oSketchLine)
 thx
how can i activate sketch command in vba?
i want to add a projected line from a face i will select.
thanksSmiley Happy
you mean this?
as example
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Create the new sketched symbol definition.
Dim oSketchedSymbolDef As SketchedSymbolDefinition
Set oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Add("Faltmarken_A1")
Dim oSketch As DrawingSketch
Call oSketchedSymbolDef.Edit(oSketch)
cu
Mario
i need the code for ipt or iam to create a projected line from a solid.
executing the sketch command is good enough for me.
