Limiting addin to specific multiple releases
LukeDavenport
LukeDavenport
I need to limit an addin to only load for Inventor releases 2014 and 2015. Referring to Adam Nagy's helpful blog here:
http://adndevblog.typepad.com/manufacturing/2014/09/addin-file-version-information-.html
According to this blog I should be able to use the following entry in the .addin file to achieve this.
  <SupportedSoftwareVersionEqualTo>14..;15..</SupportedSoftwareVersionEqualTo>
But this causes the addin to fail to load completely. Am I missing something simple with the syntax here? Is it different from the old registry method syntax for specifying multiple releases?
Many thanks for any help.
Luke
rjay75
It needs to be.
Use both together
<SupportedSoftwareVersionGreaterThan>17..</SupportedSoftwareVersionGreaterThan><SupportedSoftwareVersionLessThan>20..</SupportedSoftwareLessGreaterThan>
2014 = 18
2015 = 19
LukeDavenport
Rodney thats brilliant. Many thanks for the quick reply, will try this.
Luke
LukeDavenport
It works. Excellent skills.
