Need i-logic function for Export sketch to dwg from part file
Hello All,
 I have drawn one rectangular sketch in part model. I want to use i-logic rule or form to export that sketch to dwg format.i will use that dwg file in auto cad in future.
Please help me on this.
Thank you,
Kanagavel.M
I modified the code from the following link and made it work with the VBA editor within Inventor.
http://forums.autodesk.com/t5/inventor-customization/export-sketch-as-autocad-dwg-file-question/td-p...
Create a sketch and run this macro from the sketch enviroment.
It created a dwg file named sketch.dwg on my desktop.
Option Explicit
Sub ExportDWG()
  Dim DWGAddIn As TranslatorAddIn
Dim Doc As Document
       Set DWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
       Set Doc = ThisApplication.ActiveDocument
       Dim transObjs As TransientObjects
       Set transObjs = ThisApplication.TransientObjects
       Dim context As TranslationContext
       Set context = transObjs.CreateTranslationContext
       context.Type = kFileBrowseIOMechanism
       Dim options As NameValueMap
       Set options = transObjs.CreateNameValueMap
       If DWGAddIn.HasSaveCopyAsOptions(Doc, context, options) Then
          options.Value("Sketch") = True
          options.Value("DwgVersion") = 25
       Dim oDataMedium As DataMedium
       Set oDataMedium = transObjs.CreateDataMedium
       oDataMedium.FileName = "sketch.dwg"
       Call DWGAddIn.SaveCopyAs(Doc, context, options, oDataMedium)
End Sub
Thank you Jones,
It is working fine. I have one more question. If you can, guide me.
I want to Use this macro after finishing the sketch. You told to use in sketch environment. Instead, Is it possible way to use this macro from I-logic rules or form like that (automatically triggering from some click on buttons) ?
Thanks in advance
Kanagavel.M
