Inside the ilogic editor you are likely all ready using the the VB.NET Language for some time now. If you want to get into more advance use of VB.NET then you can get Visual studio and create WinForms and build Addin's and have more extensive debugging capabilities.
The Inventor API is what you will be wanting to drive with VB.NET. However the language the majority of the samples are written in the help documents are in VBA Language. So because of the similarities you will likely end up learning both VBA and VB.NET with conversion of the code to the VB.NET for use in the ilogic Editor. In my experience there is more general VBA content and tutorials on the internet. So what works in VBA will likely only need small changes in VB.NET. On this forum ilogic/VB.NET seems to be the more popular content.
Here are some difference between the languages when trying to work with iproperties. As you will see the ilogic snippet is the shortest but actually behind the scenes is code like the VB.NET/VBA carrying out the retrieval of the property. You will see that the VB.NET code can be shorten considerably as you can both declare and set a object variable on the same line.
iLogic
MessageBox.Show(iProperties.Value("Project", "Part Number"))
VB.NET
Sub Main
' Get the active document.
Dim invDoc As Document = ThisApplication.ActiveDocument
' Get the design tracking property set.
Dim invDesignInfo As PropertySet = invDoc.PropertySets.Item("Design Tracking Properties")
' Get the part number property.
Dim invPartNumberProperty As Inventor.Property = invDesignInfo.Item("Part Number")
MsgBox ("Part Number: " & invPartNumberProperty.value)
End Sub
VBA GetPropertySample from API
Public Sub GetPropertySample()
Set invDoc = ThisApplication.ActiveDocument
Set invDesignInfo = invDoc.PropertySets.Item("Design Tracking Properties")
Dim invPartNumberProperty As Property
Set invPartNumberProperty = invDesignInfo.Item("Part Number")
MsgBox "Part Number: " & invPartNumberProperty.value
End Sub
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
