Leader Text on an Assembly Edge
Greetings,
Using Inventor 2016
Windows 7
The following is the code for the creation of a leader on a specific edge in a part.
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
    Dim oActiveSheet As Sheet = oDrawDoc.ActiveSheet
    Dim orefdoc As PartDocument = ThisApplication.Documents.Open("K:\Inventor\IRW Drawing File\IRWBaseForDrawings.ipt", False)
    Dim oDrawingCurvesEnum As DrawingCurvesEnumerator
    Dim oEdge As Edge = orefdoc.ComponentDefinition.SurfaceBodies.Item(2).Edges.Item(11) ' edge 11 or 12
    Dim oView As DrawingView = oDrawDoc.ActiveSheet.DrawingViews.Item(1)
     oDrawingCurvesEnum = oView.DrawingCurves(oEdge)
    Dim oDrawingCurve As DrawingCurve = oDrawingCurvesEnum.Item(1)
    Dim oMidPoint As Point2d = oDrawingCurve.MidPoint
    Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
    Dim oLeaderPoints As ObjectCollection
     oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
    ' Create a few leader points.
     oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X, oMidPoint.Y+6))
     'oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X+1, oMidPoint.Y + 6))
    ' Create an intent and add to the leader points collection.
    ' This is the geometry that the leader text will attach to.
    Dim oGeometryIntent As GeometryIntent
     oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, oMidpoint)
     oLeaderPoints.Add(oGeometryIntent)
    ' Create text with simple string as input. Since this doesn't use
    ' any text overrides, it will default to the active text style.
    Dim sText As String
    sText = "ELECTRICAL CONTROL PANEL"
    Dim oLeaderNote As LeaderNote
     oLeaderNote = oActiveSheet.DrawingNotes.LeaderNotes.Add(oLeaderPoints, sText)
    Dim oFirstNode As LeaderNode
     oFirstNode = oLeaderNote.Leader.RootNode.ChildNodes.Item(1)
The following is a code that I am trying to create to have the same behavior in an assembly.
    Dim orefdoc As AssemblyDocument = ThisApplication.Documents.Open("K:\Inventor\IRW Drawing File\IRW Dev.iam", False)
    Dim oEdge As Edge = orefdoc.ComponentDefinition.Occurrences.Item(1).SurfaceBodies.Item(2).Edges.Item(11) ' edge 11 or 12
    Dim sText As String
 When I use the Microsoft Visual Basic window to help debug.  The only error appears on the following line. Invalid Procedure Call or Argument
iLogic throws off this error code:
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.DrawingView.get_DrawingCurves(Object ModelObject)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Error in rule: TestLeaders, in document: IRW Dev
I have searched and searched to try and figure out why the code is throwing this error.  It appears there is a problem with how I identified the edge on my assembly.  However, I cannot seem to find the error?
Or there is a problem with how the DrawingCurvesEnumerator is being used?
The files that I am using to figure this out are attached.
Any help that leads to a solutioin is greatly appreciated!
wayne.brill
I am able to recreate the error using the uploaded drawing and assembly. So far I am not finding the solution.
I am able to get oView.DrawingCurves(oEdge) to return the DrawingCurve in the DrawingCurvesEnumerator if I use a simple assembly I created. I need to rule out a problem with your assembly. Can you provide the complete assembly with all of the ipt files? Let me know if you want to send this to me directly.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Wayne,
Sure If I can it would probably be better to send them all directly to you.  However, There are multiple large files.
wayne.brill
Thanks for providing the full assembly.  (privately)
I have not resolved the error when using the drawing attached to this post. However if I create a new drawing and create the base and project view using the full assembly, the code below does create the leader.  (attached that drawing)
One thing I found is that it makes a difference if the referenced assembly used to get the edge is opened with the same level of detail as the assembly that is referenced by the view. In this VBA example (an update to your code) the FileManager.GetLastActiveLevelOfDetailRepresentation() is used to get the LOD.
Public Sub LeaderNote_Curves_Test()
    Set oDrawDoc = ThisApplication.ActiveDocument
    Set oActiveSheet = oDrawDoc.ActiveSheet
    'WB added
    Dim strFullFileName As String
    strFullFileName = "C:\Users\brillw\Documents\Inventor\WB_2-18-16\11864917 Leader Assembly Edge\IRW Dev.iam"
    ' Set a reference to the FileManager object.
    Dim oFileManager As FileManager
    Set oFileManager = ThisApplication.FileManager
    ' Get the name of the last active Level of Detail (LOD) Representation.
    Dim strLastActiveLOD As String
    strLastActiveLOD = oFileManager.GetLastActiveLevelOfDetailRepresentation(strFullFileName)
    ' Use the full file name and LOD name to get the full document name.
    Dim strFullDocumentName As String
    strFullDocumentName = oFileManager.GetFullDocumentName(strFullFileName, strLastActiveLOD)
    'WB END added
    'Set orefdoc = ThisApplication.Documents.Open("K:\Inventor\IRW Drawing File\IRW Dev.iam", False)
    ' Get the error on this line "oView.DrawingCurves(oEdge)" with this
   ' Set orefdoc = ThisApplication.Documents.Open("C:\Users\brillw\Documents\Inventor\WB_2-18-16\11864917 Leader Assembly Edge\IRW Dev.iam", False)
   ' WB added - Error does not occur and leader is created using this to open the LOD
    Set orefdoc = ThisApplication.Documents.Open(strFullDocumentName, False)
    Dim oEdge As Edge
    Set oEdge = orefdoc.ComponentDefinition.Occurrences.Item(1).SurfaceBodies.Item(2).Edges.Item(11) ' edge 11 or 12
    'Set oView = oDrawDoc.ActiveSheet.DrawingViews.Item(1)
    'WB added, commented above
    Set oView = oDrawDoc.ActiveSheet.DrawingViews.Item(2)
    Set oDrawingCurvesEnum = oView.DrawingCurves(oEdge)
    Set oDrawingCurve = oDrawingCurvesEnum.Item(1)
    Set oMidPoint = oDrawingCurve.MidPoint
    Set oTG = ThisApplication.TransientGeometry
    Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
     Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.x, oMidPoint.y + 6))
     'oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X+1?, oMidPoint.Y + 6))
    Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve, oMidPoint)
     Call oLeaderPoints.Add(oGeometryIntent)
    Dim sText As String
    Set oLeaderNote = oActiveSheet.DrawingNotes.LeaderNotes.Add(oLeaderPoints, sText)
    Set oFirstNode = oLeaderNote.Leader.RootNode.ChildNodes.Item(1)
End Sub
Please let me know the results you get.
Wayne
Wayne Brill
Worked Like Charm!  Thank you very much!
Your help is greatly appreciated.
