Launch External iLogic rule with VBA
Lance127
Message 1 of 40
Lance127
Is there someway to launch an external iLogic rule with VBA?. I'd like to add a button to run the iLogic rule.
Lance W.
Inventor Pro 2013 (PDS Ultimate)
Vault Pro 2013
Windows 7 64
Xeon 2.4 Ghz 12GB
Replies (39)
Message 21 of 40
Regarding your error.  My bad.  The line with the error should start with:
AddIn
Not
DXFAddin
Regarding using the Print to PDF.
The code is still there.
You just need to UNCOMMENT it and delete or Comment the current PDF Translator code in the Traslator Sub Routine.
Message 22 of 40
For instance change the Elseif FileType = ".pdf" section as follows.
  ElseIf FileType = ".pdf" Then
    Dim oPrintMgr as Inventor.PrintManager
    Set oPrintMgr = ThisApplication.ActiveDocument.PrintManager
    oPrintMgr.Printer = "Adobe PDF"
    oPrintMgr.ColorMode = kPrintGrayScale
    oPrintMgr.ColorMode = kPrintColorPalette
    oPrintMgr.NumberOfCopies = 1
    oPrintMgr.Orientation =    kPortraitOrientation
    oPrintMgr.Orientation = kLandscapeOrientation
    oPrintMgr.PaperSize = kPaperSizeA4
    oPrintMgr.SubmitPrint
    Exit Sub
End If
Message 23 of 40
I have correct the AddIn 🙂 but don't work again 🙂 excuse me but i don'k know nothink in vba. When this code works i try to change printer 😄
Message 24 of 40
Ah!  I missed something there.  To make the code work in my environment I had to edit some of the parameters as you had hard coded them for your network / PC.
Remove the "Nothing, " parameter from the statement.
Beyond that I cannot do much more for you without sitting beside you at your workstation.
If you want to use VBA or iLogic then you are going to have to be willing to learn somethning about the topic.
Message 25 of 40
OK 😄 it's work perfectly!! Thank you very much!!!
There is one little things, when he save the dxf file the neme of the file il the Part Number of iProperties, i need the name is the name of the file.
For exemple
SO37697.ipt ==> SO37697.dxf
Because in my iLogic for first i do this:
iProperties.Value("Custom", "FileName") = ThisDoc.FileName(True)
iProperties.Value("Project", "Part Number") = ThisDoc.FileName(False)
 d
Message 26 of 40
Varga,
If you want the filename then you can derive it from the oDocument object.
The property you want is called FullFileName.
(When in the VBA environment place a period after any object to see what properties and methods it contains.)
' Change the sub routine: Output_DXF_PDF to:
Public Sub Output_DXF_PDF()
  Dim oDocument As Inventor.Document
  Dim sPath As String
  Dim PN As String
  ' VBA requires the keyword "Set" when instantiating an Object variable
   Set oDocument = ThisApplication.ActiveDocument
  ' Set Path and base file name
  sPath = "C:\Users\varga\Desktop\"
  PN = GetFileName(oDocument.FullFileName)
  PN = sPath & PN
  ' Call the translation sub routines
  Call TranslateFile(PN, ".dxf", oDocument)
  Call TranslateFile(PN, ".pdf", oDocument)
  ' Clean up objects
  Set oDocument = Nothing
End Sub
' Add the following Function (It is used in the above sub routine.)
Private Function GetFileName(Byval sFullFileName as string) as string
  Dim sFileName as string
  Dim nPos as integer
  Dim sFileName = sFullFileName
  nPos = instrRev$(sFullFileName,"\")
  if nPos > 0 then
    sFileName = Mid$(sFullFileName,nPos+1)
  End if
  GetFileName = sFileName
End Function
Message 27 of 40
So 😄 i have modify all for my need. It works fine but i have the last bug. This in my final code:
'Crea i PDF con adobe PDF
Option Explicit
Public Sub DXF_PDF_Creator()
  Dim oPropertySet As Inventor.PropertySet
  Dim oProperty As Inventor.Property
  Dim sPath As String
  Dim PN As String
  Set oPropertySet = oDocument.PropertySets(("Design Tracking Properties"))
  Set oProperty = oPropertySet("Part Number")
  PN = sPath & PN
  ' Clean up object
  Set oProperty = Nothing
  Set oPropertySet = Nothing
End Sub
Private Function GetFileName(ByVal sFullFileName As String) As String
  Dim sFileName As String
  Dim nPos As Integer
  nPos = InStrRev(sFullFileName, "\")
  If nPos > 0 Then
    sFileName = Mid$(sFullFileName, nPos + 1)
  End If
End Function
Public Sub TranslateFile(ByVal BaseFileName As String, ByVal FileType As String, oDocument As Inventor.Document)
  Dim PN As String
  PN = BaseFileName & FileType
  ' Define Variables
  Dim AddIn As Inventor.TranslatorAddIn
  Dim oContext As Inventor.TranslationContext
  Dim oOptions As Inventor.NameValueMap
  Dim oDataMedium As Inventor.DataMedium
  Dim SheetSize As DrawingSheetSizeEnum
  Dim SheetOrientation As PageOrientationTypeEnum
  ' Define Context, Options and DataMediums
  Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
  oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
  Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
  Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
  If FileType = ".dxf" Then
    ' Get the DXF translator Add-In.
    Set AddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
  ' Check whether the translator has 'SaveCopyAs' options
    If AddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
      Dim strIniFile As String
      strIniFile = "Z:\Autodesk\Inventor11\Design Data\DWG-DXF\fornitori.ini"
      oOptions.Value("Export_Acad_IniFile") = strIniFile
    End If
    Dim oPrintMgr As Inventor.PrintManager
    SheetOrientation = ThisApplication.ActiveDocument.ActiveSheet.Orientation
    'SheetSize = ThisApplication.ActiveDocument.ActiveSheet.Size
        'Create a PDF File with the print manager
        'oPrintMgr.ColorMode = kPrintGrayScale
        'oPrintMgr.ColorMode = kPrintColorPalette
        ' Imposta l'orientazione del PDF
        If SheetOrientation = kLandscapePageOrientation Then
        ElseIf SheetOrientation = kPortraitPageOrientation Then
        End If
        'oPrintMgr.Orientation = kPortraitOrientation
        'oPrintMgr.Orientation = kLandscapeOrientation
        Exit Sub
  End If
  ' Set the destination file name
  oDataMedium.FileName = PN
  ' Create a DXF document
  Call AddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
  ' Clean up objects
  Set oDataMedium = Nothing
  Set oOptions = Nothing
  Set oContext = Nothing
  Set AddIn = Nothing
End Sub
 For exemple with file SO37697.dwg open in inventor when i lunch this code he do two file SO37697.dwg.dxf and SO37697.pdf the dxf is wrong, and he doesn't consider tht .ini file!!! Why??
Message 28 of 40
Varga,
I have reached the limit of what I can do without being at your desk.
It might be that your ini file is not at the path you have in code.  Those .INI files for DWG/DXF are a mystery to me. Historically the output options tend to be sticky.   You might want to manually dump a DXF file and look at the output option settings.  Make sure they are set to "Drawing" Ect...
You might put a break in your code just before the section "If AddIn.HasSaveCopyAsOptions..." and step ;through your code with F8  in debug mode to see what is happening.  (To put a break on a line of code click in the gray column to the far left in the text editor  A Brown dot should appear there.  Run your program.  It will stop when it reaches the brown dot.  Use F8 to step line by line forward.  Hover over your variables they should display their current contents when in Debug mode.)
The VBA Help for Programming is in Inventor on the upper right, under the blue question mark pull down. Select  "Additional Resoruces | Programming Help"  Use the search tab of the help dialog and enter. "Addin DXF" Select "TranslatorAddIn Interface "  Scroll down to the DXF example.
Message 29 of 40
Ok thank you very much i look for the solution, i think is guilt of the file name script which put the extension .dwg at the end of the name so if he create the dxf the result is filename.dwg.dxf 😄
Thank YOU for all you help!
Message 30 of 40
No Problem,
Change the GetFileName sub routine to the following to remove the .DWG from the filename.
  Dim nPos As Integer
  If nPos > 0 Then
  End If
  nPos =  InStrRev(sFullFileName, ".")
  If nPos > 0 then
    sFileName = Left$(sFileName, nPos-1)
  End if
End Function
Message 31 of 40
Ok but there is somethink who i don't understand:
I open thi file: Z:\DISEGNI_INVENTOR\MO\MO37618.dwg
Private Function GetFileName(ByVal sFullFileName As String) As String  => (Here GetFileName is Z:\DISEGNI_INVENTOR\MO\MO37618.dwg)
  Dim sFileName As String  ==> (sFileName is MO37618.dwg)
  Dim nPos As Integer ==> (nPos in 31)
  sFileName = sFullFileName ==> (sFileName is MO37618.dwg and sFullFileName is Z:\DISEGNI_INVENTOR\MO\MO37618.dwg)
  If nPos > 0 Then
    sFileName = Mid$(sFullFileName, nPos + 1) ==> (sFileName is MO37618.dwg)
  End If
  nPos =  InStrRev(sFullFileName, ".") ==> (nPos in 31)
  If nPos > 0 then
    sFileName = Left$(sFileName, nPos-1) ==> (sFileName is MO37618.dwg)
  End if
  GetFileName = sFileName ==> (GetFileName and sFileName is MO37618.dwg)
End Function
so after this the pdf when i go to save is MO37618.dwg.dxf 🙂
I study this code but i don't find the error 😄
Message 32 of 40
Yesssssssssssss i have solved!!!!
Now is perfect!!!!! This is the correct function for the name .-D
  Dim nPos  As Integer
  Dim nPosf As Integer
  If nPos > 0 Then
  End If
  nPosf = InStr(sFullFileName, ".")
  If nPos > 0 Then
    sFileName = Left$(sFileName, nPosf - nPos - 1)
  End If
End Function
Message 33 of 40
Glad your starting to get into programming.
In any case I am guilty of not testing my code before  I post it.
Here is the GetFileName() function I posted Corrected.
  Dim nPos As Integer
  nPos = InStrRev(sFileName, "\")
  If nPos > 0 Then
    FileName = Mid$(sFileName, nPos + 1)
  End If
  nPos = InStrRev(sFileName, ".")
  If nPos > 0 Then
    sFileName = Left$(sFileName, nPos - 1)
  End If
End Function
Message 34 of 40
dfitting
Hi, I have read this post and I am unable to get it to work for my ilogic rule.
Ive created the external ilogic rule and saved it in my documents folder(is this where it should be, or should it be in my inventor files?)
Anyways, now that I have the VBA created and a button made to access the macro, its not doing anything once it is pressed. I am not sure where I went wrong here, but here is the VBA Code I have from the 1st page:
Public Sub ZXPlane()
RuniLogic "ZXPlane"
End Sub
Public Sub RuniLogic(ByVal RuleName As String)
Dim iLogicAuto As Object
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
If oDoc Is Nothing Then
MsgBox "Missing Inventor Document"
Exit Sub
End If
Set iLogicAuto = GetiLogicAddin(ThisApplication)
If (iLogicAuto Is Nothing) Then Exit Sub
iLogicAuto.RunExternalRule oDoc, RuleName
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
Set addIns = oApplication.ApplicationAddIns
'Find the add-in you are looking for
Dim addIn As ApplicationAddIn
On Error GoTo NotFound
Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79?-2179-4b11-8a5a-257b1c0263ac}")
If (addIn Is Nothing) Then Exit Function
addIn.Activate
Set GetiLogicAddin = addIn.Automation
Exit Function
NotFound:
End Function
Is there something that I did wrong when I changed the 1st 2 lines?
Message 35 of 40
skyngu
please look at the line "itembyID", there is "question mark" over there. it happens when you copy and paste code from webbrowser.
Autodesk Inventor Professional 2019
Message 36 of 40
dfitting
Thanks, works like a charm now!!
Message 37 of 40
L.van.Gorsel
jcneal, Thanks alot!!!! I'm so happy. I've tried to get this function working alots of time. Now it works!
Green check.png  Please mark "Accept as Solution" if it answers your question or "Kudos" if you found it useful
Autodesk Inventor 2013, 2014 & 2015 Certified Professional
Message 38 of 40
Yijiang.Cai
Please see the example to export PDF, and you could get the tips to fix the issue -
Public Sub PublishPDF()
' Get the PDF translator Add-In.
Dim PDFAddIn As TranslatorAddIn
Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
Dim oContext As TranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
' Options for drawings...
oOptions.Value("All_Color_AS_Black") = 0
'oOptions.Value("Remove_Line_Weights") = 0
'oOptions.Value("Vector_Resolution") = 400
'oOptions.Value("Sheet_Range") = kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
'Set the destination file name
oDataMedium.FileName = "c:\temp\test.pdf"
'Publish document.
Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
Message 39 of 40
Yijiang.Cai
End If
'Publish document.
End Sub
River Cai
Autodesk, Inc.
Message 40 of 40
utm007
Hi to all.
I'm with Inventor 2021
and i have an exit sub when--> RuniLogic "MyRule"
in
[...] If (iLogicAuto Is Nothing) Then Exit Sub[...]
Maybe the code changes for Inventor 2021?
Can someone help me?
