IV2008 - DataIO - Write to DXF - Options and limitations
Message 1 of 10
Several comments on the API help:
1) The page of the DataIO Object says:
"Below are the names of these arguments and their default values"
But the table only includes "Argument", "Type" and "Note".
The table does NOT show the default values of the arguments.
2) "SimplifySplines" (Boolean)
What is the default value?? (see remark 1)
Is this setting PER layer of for the ENTIRE DXF?
3) "SplineTolerance" (Double)
What is the default value? (see remark 1)
Is this value in centimeters (the internal unit of Inventor)?
4) "AdvancedLegacyExport" (Boolean)
What does this?
5) "RebaseGeometry" (Boolean)
What does this?
6) Regarding Bend Angles
With an Inventor DWG, we can show the Bend Angle in the flatpattern (as a
note). Can this value be exported to a DXFas well? (For example, AutoPOL can
do this)
7) Regarding Layers and Colors
We can determine the name of the layer, but can we override the color of an
entity on that layer?
(For example, I want to put all the bendlines on Layer 0, but the bendlines
must be YELLOW (and not WHITE (the default color of the layer))
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 6.14.10.9185)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
Autodesk Inventor Suite 2008 SP1
Replies (9)
Message 2 of 10
"7) Regarding Layers and Colors
We can determine the name of the layer, but can we override the color of an entity on that layer?
(For example, I want to put all the bendlines on Layer 0, but the bendlines must be YELLOW (and not WHITE (the default color of the layer))"
I reckon you still need to create the DXF file, then hack it to set the line colours using an add-in!
I need the following in my DXF's -
Layer - OUTLINE, Colour - WHITE, Laser cut lines
Layer - PRESS, Colour - YELLOW, Etch lines
Layer - TEXT, Colour - RED, Etched text (ISO9)
I'm about to start programming........
Message 3 of 10
I could still use the awnsers on my questions...
Is any one from Autodesk around to fill these blanks???
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Message 4 of 10
I've attached an updated table of DXF options.
SimplifySplines is for the entire DXF.
Spline tolerance is in cm.
Hope this helps.
Sanjay-
Argument
Type
Default Value
Note
TangentLayer
String
IV_TANGENT
OuterProfileLayer
String
IV_OUTER_PROFILE
ArcCentersLayer
String
IV_ARC_CENTERS
InteriorProfilesLayer
String
IV_INTERIOR_PROFILES
BendLayer
String
IV_BEND
BendUpLayer + BendDownLayer (legacy support)
BendUpLayer
String
IV_BEND
BendDownLayer
String
IV_BEND_DOWN
ToolCenterLayer
String
IV_TOOL_CENTER
ToolCenterUpLayer + ToolCenterDownLayer (legacy support)
ToolCenterUpLayer
String
IV_TOOL_CENTER
ToolCenterDownLayer
String
IV_TOOL_CENTER_DOWN
FeatureProfilesLayer
String
IV_FEATURE_PROFILES
FeatureProfilesUpLayer + FeatureProfilesDownLayer (legacy support)
String
IV_FEATURE_PROFILES
String
IV_FEATURE_PROFILES_DOWN
AltRepFrontLayer
String
IV_ALTREP_FRONT
AltRepBackLayer
String
IV_ALTREP_BACK
CustomizeFilename
String
AcadVersion
String
2007, 2004, 2000, or R12 (for DXF only)
SimplifySplines
Boolean
TRUE
Enable spline replacement by linear segments
SplineTolerance
Double
0.01
Chord tolerance for spline replacement
Boolean
TRUE
MergeProfilesIntoPolyline
Boolean
FALSE
Build a polyline of the exterior profiles
RebaseGeometry
Boolean
FALSE
Move geometry to 1st quadrant
InvisibleLayers
String
List of layer names to make invisible, separated by ;
"Teun Ham (IV10 SP3 / IV2008 SP1)"
wrote in message news:5744132@discussion.autodesk.com...
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Message 5 of 10
I've attached a word doc with the table. Much more readable :).
Sanjay-
"Sanjay Ramaswamy (Autodesk)" wrote in
message news:5744778@discussion.autodesk.com...
Hope this helps.
Sanjay-
Argument
Type
Default Value
Note
TangentLayer
String
IV_TANGENT
OuterProfileLayer
String
IV_OUTER_PROFILE
ArcCentersLayer
String
IV_ARC_CENTERS
String
BendLayer
String
IV_BEND
BendUpLayer
String
IV_BEND
BendDownLayer
String
IV_BEND_DOWN
ToolCenterLayer
String
IV_TOOL_CENTER
ToolCenterUpLayer
String
IV_TOOL_CENTER
ToolCenterDownLayer
String
IV_TOOL_CENTER_DOWN
String
IV_FEATURE_PROFILES
String
IV_FEATURE_PROFILES
String
AltRepFrontLayer
String
IV_ALTREP_FRONT
AltRepBackLayer
String
IV_ALTREP_BACK
CustomizeFilename
String
AcadVersion
String
SimplifySplines
Boolean
TRUE
SplineTolerance
Double
0.01
Boolean
TRUE
Boolean
FALSE
RebaseGeometry
Boolean
FALSE
InvisibleLayers
String
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Message 6 of 10
Thanks Sanjay!
That's indeed much more readable 🙂
Would you also have an answer to questions 6 & 7? (Or am I asking too much?
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Message 7 of 10
"Would you also have an answer to questions 6 & 7? "
Sanjay,
I also have an interest in these questions
Message 8 of 10
Unfortunately, the answer to both questions 6 & 7 is no. The API does not
offer any facilities to do this.
Sanjay-
wrote in message news:5745205@discussion.autodesk.com...
Sanjay,
Message 9 of 10
So it's still DXF hacking time... ho hum.
Message 10 of 10
That's a pity...put it on the wishlist!
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
