IV2008 - Bendlines of legacy sheetmetal files are NOT exported correctly to DXF - Bendlines are put on wrong layer!
See attached dataset (the names are self-explanatory)
The dataset contains a simple sheetmetal part (a revolve) with flat pattern,
which is created in IV10. From the sheetmetal flat pattern, a DXF file has
been generated.
The dataset also contains a migrated version of the part. From this migrated
part a second DXF file is created.
If you look at the DXF file of the IV10 part, you will see that all lines
are put on the correct layer.
On the DXF file of the migrated part, the BEND line has been put on the
WRONG LAYER. The Bendline is treated as a FeatureProfile!
This means that ALL our DXF files of our migrated sheetmetal files (which
are created with a revolve) are WRONG.
This is NOT acceptable.
If I delete the flatpattern in IV2008 and recreate it, the DXF output is
correct.
But this means that ALL VIEWS of my flat pattern are DELETED.
Once again, this is NOT acceptable
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 6.14.10.9185)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
Autodesk Inventor Suite 2008 SP1
Dataset
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Do you see the same behavior when generating the DXF via the UI or does the
problem show only via the API?
Sanjay-
"Teun Ham (IV10 SP3 / IV2008 SP1)"
wrote in message news:5732014@discussion.autodesk.com...
Dataset
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
Yes, the behaviour is the same
T. Ham
CDS Engineering BV
4 GB SDRAM
3Com Gigabit NIC
