IV11 SP2 - Can I sort The BOM
Can I sort the BOM (Not the Parts List) via the API? (Sorting the parts list I can already do)
Regards
MattH
Sorry, sorting of the BOM is currently not supported in the API.
Sanjay-
wrote in message news:[email protected]...
I can already do)
Regards
MattH
OK, How do we sort (correctly) the Dwg No column in the parts list
Sorting the BOM (manually) by Dwg No, renumber items, then sort the IDW Parts List by item number (manually or via API) is a half way workaround.
Any ideas?
The BOM sorts correctly on the Dwg No column, BUT Parts Lists do not work on the Dwg No column...
Regards
MattH
Do you mean the Part Number column? If not, could you elaborate? And I'm not
sure what you mean by PartsList not being able to sort the Dwg No column.
Could you explain?
Sanjay-
Any ideas?
Regards
MattH
Sorry, yes I mean the Part Number column
See thread
"IV11 SP2 - Parts List Sorting = UNACCEPTABLE"
Parts lists STILL do NOT sort correctly on Dwg No
1598P --- Should Be --- 1499C
1781Y ------------------- 1549J
1499C ------------------- 1550K
1549J ------------------- 1598P
1550K ------------------- 1781Y
Regards
MattH
Yup, they screwed that one up...big time!
T. Ham
Mechanical Engineer
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 8.4.2.6)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
The API provides a way to reposition parts list rows
(PartsListRow.Reposition method). So if you are able to arrive at the
correct order of part numbers, you should be able to simulate a sort using
this method.
Sanjay-
See thread
Regards
MattH
