IV 2016 SDK install error - serious error installing DeveloperTools.msi from SDK
Message 1 of 27
everytime I try to install the DeveloperTools.msi from the SDK of Inventor 2016, I got this serious error:
"A script required for this install to complete could not be run." - see screenshot 1.
Right before the error occurs, I see a command window popping up with "C:\Users\<Username>\AppData\Local\Temp\UpdateTypeLibPath.exe" - see screenshot 2.
I tried this on 2 workstations, both with the same result: the DeveloperTools could not be installed.
The UserTools.msi installs fine everytime.
The workstations are configured as follows:
- Windows 7 x64 (german)
- Office 2010 (german)
- Visual Basic 2010 Express (german)
- Inventor 2016 (english with additional german language pack)
All components are fully updated.
Any hints???
Kind regards
Replies (26)
Message 21 of 27
I am getting the same error.  Windows 8 Inventor 2016 SDK installer.  When I check the temp folder you mentioned, I see no executable installed there after this error occurs but prior to clicking the OK button on the installer error.
Your instructions for disabling a Microsoft KB fix worked for us.  Thank you.
Message 22 of 27
m_hermann
Same error,
WIN7 - 64
Inventor 2016
full Admin rights
UAC down
Language= german, maybe this is the problem
Message 23 of 27
Please try the workaround in the post #16, and let me if it works:
http://forums.autodesk.com/t5/inventor-customization/iv-2016-sdk-install-error-serious-error-install...
Message 24 of 27
kmiller
Reg key's worked for me to get it installed.
If this response answers your question please click "Accept as Solution".
Message 25 of 27
m_hermann
deinstall KB3072630 worked
Many thanks
Message 26 of 27
sgwilliams
FYI. I was having this issue also with my Windows 10 Professional 64 bit with Inventor 2016 Professional. I run the "KB3072630Disabled.reg" file, did the install, it worked like a charm then run the "KB3072630Enabled.reg" file and I'm good too go. Thought you other Windows 10 users would like a heads up. Good luck.
PS I attached the reg files in a zip file for your convenience....so you don't have to go back too the other post.
Work Station : Custom built, Liquid Cooled, Asus Pro WS X570-ACE Motherboard; AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor; ASUS TUF Gaming NVIDIA GeForce RTX 3060 V2 OC Edition Video Card; 32 GB CORSAIR Dominator Platinum DDR4-2132 Memory ; Samsung 850 EVO 1TB SSD Drive.
Message 27 of 27
AHoward321
This should be at the top of the solutions page.!
