Appearance Asset giving error
The following code gives error,
 strRS = "Oxidized"
            Dim strChrome As String = "Chrome - Polished"
            Try
                oAppAsset = oPartDoc.AppearanceAssets.Item(strRS)
                oAppAsset2 = oPartDoc.AppearanceAssets.Item(strChrome)
            Catch ex As Exception
                Try
                    oAppAsset = m_inventorApplication.AssetLibraries.Item("Autodesk Appearance Library").AppearanceAssets.Item(strRS)
                    oAppAsset2 = m_inventorApplication.AssetLibraries.Item("Autodesk Appearance Library").AppearanceAssets.Item(strChrome)
               End Try
            Try
                oPartDoc.ActiveAppearance = oAppAsset
                MsgBox("error changing active appearance" & vbCrLf & ex.Message)
            End Try
            Try
                   osolidRev1.Faces.Item(4).Appearance = oAppAsset2
                    osolidRev1.Faces.Item(7).Appearance = oAppAsset2.
                   osolidRev1.Faces.Item(10).Appearance = oAppAsset2
                   osolidRev1.Faces.Item(12).Appearance = oAppAsset2
                'Dim oChrome As RenderStyle
                'oChrome = oPartDoc.RenderStyles.Item("Chrome - Polished")
                'osolidRev1.Faces.Item(4).SetRenderStyle(StyleSourceTypeEnum.kOverrideRenderStyle, oChrome)
                'osolidRev1.Faces.Item(7).SetRenderStyle(StyleSourceTypeEnum.kOverrideRenderStyle, oChrome)
                'osolidRev1.Faces.Item(10).SetRenderStyle(StyleSourceTypeEnum.kOverrideRenderStyle, oChrome)
                MsgBox("error changing face appearance" & vbCrLf & ex.Message)
            End Try
 in the above code error occurs while changing the face appearance asset. If i use the old SetRenderStyle method then it works good. Is the above code for face appearance to use asset is the correct syntax or 2016 API issue?
could it be cause you have a dot at the end this instruction line ?
Best regards,
J-S
Thanks for your replay, that dot is a typo on the post not in the actual code. if dot is present error will popups when typing / compiling itself in VS 2013 Express.
Solved by copying the asset to document level.
                    oAppAsset2 = g_inventorApplication.AssetLibraries.Item("Autodesk Appearance Library").AppearanceAssets.Item(strChrome)
                    oDocAsset = oAppAsset2.CopyTo(oPartDoc)
 With osolidRev1
                        .Faces.Item(4).Appearance = oDocAsset
                        .Faces.Item(7).Appearance = oDocAsset
                        .Faces.Item(10).Appearance = oDocAsset
                        .Faces.Item(12).Appearance = oDocAsset
                        .Faces.Item(15).Appearance = oDocAsset
                    End With
