How to imput parameter using Ilogic rule when creating a new part.
I would like to write a Ilogic rule that comes with a question screen, where I can enter some parameter, when I create a new part.
Excempel: I have a template for a steel plate with a scetch. I need to input 3 parameter: length, width and thickness. So the rule should come with those 3 questions: input length, input width and input thickness.
Don't think it is very complicated but I couldn't figure it out. Appreciate all help.
Toon
mwighton
Do you want the iLogic to be specific to that part file or for any part file you open??
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
I only want to do it with some of my template files. External rule and trigger new document.
That is not the probem 😄
Toon
mwighton
This is code that I just wrote that works. If this is not what you were looking for let me know and I will try to fix it to get what you want.
SyntaxEditor Code Snippet
Length = InputBox("Input Length", "Length", Length)
Width = InputBox("Input Width", "Width", Width)
Thickness = InputBox("Input Thickness", "Thickness", Thickness)
iLogicVb.UpdateWhenDone = True
God Bless
Mwighton
Hello Mwighton,
Your rule works fine, I get the questions I want but is it possible to assign my answers to an existing parameter and update the part?
Toon
Never mind, I figured that part out myself. Thanks for your help.
Toon
mwighton
No Problem. Glad I could help.
God Bless
Mwighton
