iTrigger- Form
iTrigger- Form
Cosmin_V
iTrigger- Form
Cosmin_V
HI,
I have an iLogic assembly whit some forms, which are open by iTrigger.
The form have 5 Tab Groups. When the form is open, is open on the tab 4.
How can I constrain it to start on first one when is trigger?
Like this is now.
And I what it like this.
Many Thanks!
MjDeck
When you close the form, the currently selected tab is saved. Then when you open the form again, that same tab is selected. There is no option to select another tab.
We could add an option like that to the iLogicForm.Show() function.
Another possibility would be to add an option to the form that says "don't remember the last selected tab". Would that be useful? Would you be happy to always start on the first tab in this form, even when it is not launched by iTrigger?
Mike Deck
Software Developer
Autodesk, Inc.
Cosmin_V
Hi
MjDeck
@Cosmin_V , which version of Inventor are you using?
The form should start up with the same tab selected that was selected when it closed. There is no need to open the form for editing.
If this isn't working on your form, can you post your model (or a simpler model that shows the same problem)?
Mike Deck
Software Developer
Autodesk, Inc.
Cosmin_V
@MjDeck
I use Inventor 2016.2.9.
That's how I thought, for a while but is seems that it is not so.
Unfortunately I can't share my model here. You have to believe me.😁
It seems that if I "Resize Controls", which tab will be "On" when "Exit Resize Mode" whit that one will start the form.
Many Thanks!
MjDeck
@Cosmin_V , I see the problem now. It happens if you use Resize Controls.
This is a defect, but you can take advantage of it.
- select the tab that you want to be the starting tab
- choose the Resize Controls command (but you don't need to actually resize anything)
- close the form
Now the form will open to that tab the next time.
Mike Deck
Software Developer
Autodesk, Inc.
lena.talkhina
Hello @Cosmin_V  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
