it is possible savc an drawing as PDF and have the PDF have an standard comment on it ?
Darkforce_the_ilogic_guy
Advisor Advisor
I have an review tools that open and save all new drawing as PDF. and that work fine.
but I want to add an check list as an Comment on the PDF so the person that are review the drawing need as minimun need to check.
the comment will change ... after what partnummer the PDF is create form.
is there a way to do this  ?
SometimesInventorMakesMeAngry
I don't think Inventor can edit PDF's-- it only exports them. You can export them with the sample here. I believe there is an SDK for Adobe Acrobat that you might be able to use to edit the PDF, but I'm not familiar with it.
thank for the like to the code. But I already have a bettere version that can take all Drawing form an iam, and only the new drawing that need a review 😁 so I got that cover. But what I am trying to do is to make an even better version. with helt to the reviewer to remember what he/she need to check. Our drawing is very complex. and there is a lot to remember. and the Company rules for how a drawing should minimun have change all the time.  So it is a way to have the information available in a n easy way as possible. I  have it so far the code needed to make an excel sheet with the part  number and what need to get done.. but i fear it might be too most work to use
