Issues with FormattedText
gilsdorf_e
gilsdorf_e
Hello all,
I wanted to remove style overrides from our titleblock. As there are many, many textboxes, I wanted to do this in an automated way.
There seems to be an issue with writing to FormattedText property.
The code is like
 Inventor.Application invApp;
            invApp = (Inventor.Application)System.Activator.CreateInstance(System.Type.GetTypeFromProgID("Inventor.Application"));
            DrawingDocument drawDoc = (DrawingDocument)invApp.Documents.Open(@"Z:\_pdm\flg\Administration\Inventor\2014\Templates\Drawing_DE_EN.dwg");
            TitleBlock tBlock = drawDoc.ActiveSheet.TitleBlock;
            DrawingSketch sketch = tBlock.Definition.Sketch;
            TextBoxes tboxes = sketch.TextBoxes;
            foreach(TextBox tbox in tboxes)
                tbox.Style = drawDoc.StylesManager.TextStyles["Iso"];
                String text = tbox.FormattedText;
                tbox.FormattedText=tbox.FormattedText.Replace("ISOCPEUR", "ISOCP");
            drawDoc.SaveAsInventorDWG(@"c:\temp\test.dwg",true);
even if I say
tbox.FormattedText = tbox.FormattedText
without changing anything, this still causes an exception.
Best regards
Erik
Try
tbox.FormattedText=text.Replace("ISOCPEUR", "ISOCP");
Or even:
String text = tbox.Text;
tbox.Text=text.Replace("ISOCPEUR", "ISOCP");
That's what I would try...
gilsdorf_e
that has been my first try. Somewhere on the internet it says there might be problems with custom iProperties.
tbox.Text cannot be used in my opinion, as I do not want to change the text but the formatting.
Best regards
Erik
gilsdorf_e
Solved it.
I forgot to enter edit mode for the titleblock sketch
tBlock.Definition.Edit(out sketch);
That did the trick.
Best regards
Erik
rossano_praderi
Hi Erik,
I had the same problem some time ago, I tried to change the formatted text with the "Replace" function and something went wrong.
Then I've tried the following solution and it started working properly
http://forums.autodesk.com/t5/inventor-customization/changing-text-in-description-column-of-a-holeta...
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
