Issue with PDF Export Macro in Autodesk Inventor for Revision Handling in VBA
shubham.raturi2308
shubham.raturi2308
This PDF export macro for Autodesk Inventor, created using Visual Basic for Applications (VBA), functions correctly by referencing the properties of linked documents. For revisions with a value of 0, the macro performs as expected. However, for revisions with a value of 1, the macro initially fails to work as intended, but functions correctly on the second attempt. This issue persists across other revision values as well. I am getting the values from part or assembly which ever is inserted in the drawing sheet.
Private Function ExportPDF(oDoc As Document) As String
    ' Create PDF filename and path
    Dim basePath As String
    Dim pdfPath As String
    pdfPath = "C:\INV\Macros\"
    Dim pdfAddin As TranslatorAddIn
    Dim oContext As TranslationContext
    Dim oOptions As NameValueMap
    Dim oDataMedium As DataMedium
    Set pdfAddin = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    If pdfAddin.HasSaveCopyAsOptions(oDoc, oContext, oOptions) Then
        ' Default options
        oOptions.Value("All_Color_AS_Black") = 0
        oOptions.Value("Remove_Line_Weights") = 0
        oOptions.Value("Vector_Resolution") = 400
        oOptions.Value("Sheet_Range") = kPrintAllSheets
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
     Dim pdfFileName As String
    ' Remove .dwg or .idw from the filename
    Dim baseFileName As String
    baseFileName = Left(oDoc.DisplayName, InStrRev(oDoc.DisplayName, ".") - 1)
    ' Get the description property
    Dim Description As String
    Description = GetDescription(oDoc)
    ' Get the Revision Number property
    Dim RevisionNumber As String
    RevisionNumber = GetRevisionNumber(oDoc)
    ' Get the Part Number property
    Dim PartNumber As String
    PartNumber = GetPartNumber(oDoc)
   pdfFileName = PartNumber & "_" & RevisionNumber & "_" & Description & ".pdf"
    oDataMedium.filename = pdfPath & pdfFileName
    On Error Resume Next
    Call pdfAddin.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
    ExportPDF = pdfFileName
    If Err.Number <> 0 Then
        MsgBox "Error exporting PDF: " & Err.Description, vbExclamation
    Else
        'MsgBox "PDF exported successfully!", vbInformation
    On Error GoTo 0
End Function
Private Function GetDescription(drawingDoc As Document) As String
    If Not TypeOf drawingDoc Is DrawingDocument Then
        GetDescription = "NoDescription"
        Exit Function
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = drawingDoc
    ' Get the referenced document
    Dim referencedDoc As Document
    Set referencedDoc = oDrawDoc.ReferencedDocuments.Item(1)
    If Not referencedDoc Is Nothing Then
        ' Try to get description from Design Tracking Properties
        Dim propSet As PropertySet
        Set propSet = referencedDoc.PropertySets("Design Tracking Properties")
        If Not propSet Is Nothing Then
            GetDescription = CStr(propSet.Item("Description").Value)
            If Err.Number = 0 And Len(Trim(GetDescription)) > 0 Then
                Exit Function
        ' If not found, try Summary Information
        Err.Clear
        Set propSet = referencedDoc.PropertySets("Inventor Summary Information")
            GetDescription = CStr(propSet.Item("Title").Value)
                Exit Function
    On Error GoTo 0
End Function
Private Function GetRevisionNumber(drawingDoc As Document) As String
        GetRevisionNumber = "0"
        Exit Function
    ' Try to get the referenced document directly
        Err.Clear
        ' Get the PropertySet - now using "Inventor Summary Information"
            Dim revValue As String
            revValue = CStr(propSet.Item("Revision Number").Value)
            If Err.Number = 0 And Len(Trim(revValue)) > 0 Then
                GetRevisionNumber = revValue
                Exit Function
    On Error GoTo 0
End Function
Private Function GetPartNumber(drawingDoc As Document) As String
        GetPartNumber = "NoPartNumber"
        Exit Function
        ' First try Design Tracking Properties
            GetPartNumber = CStr(propSet.Item("Part Number").Value)
            If Err.Number = 0 And Len(Trim(GetPartNumber)) > 0 Then
                Exit Function
        Err.Clear
                Exit Function
    On Error GoTo 0
End Function
@WCrihfield, @jnowel , @Michael.Navara , @Curtis_Waguespack , @Andrii_Humeniuk , @JelteDeJong , @J-Camper , @A.Acheson , @bradeneuropeArthur
Ralf_Krieg
Hello
I have tried your code and it works as expected with any revision number. What happens when your first attempt fails? Any error message? Have you tried stepping through code in debugging mode and check variable values?
R. Krieg
RKW Solutions
www.rkw-solutions.com
shubham.raturi2308
There is no actual error, but the popup displays an incorrect revision number. However, the file itself is created with the correct revision number.
I’m just guessing, but it might be saving the revision value somewhere and retrieving it from there instead of updating it each time.
Ralf_Krieg
Hello
There is no popup showing the revision number in your posted code.
R. Krieg
RKW Solutions
