Constraint Occurences flashing with highlight set
SevInventor
SevInventor
Hey Guys,
I've found this usefull rule to get the occurences and their enitys.
Gelöst: Find Entities - Autodesk Community - Inventor
How could the highlight set be used to get the Occurence1, Enity1, Occurence2, Enity2 flashing alternately instead of the text box?
Nice would be also if the Occurence/Enity names show up in the status bar while its Highlighted.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.", vbCritical, "")
		Exit Sub
	Dim oADoc As AssemblyDocument = ThisDoc.Document
	Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
	Dim oOccs As ComponentOccurrences = oADef.Occurrences
	Dim oConsts As AssemblyConstraints = oADef.Constraints
	For Each oConst As AssemblyConstraint In oConsts
		'if the constraint is suppressed, then skip to next constraint
		'can't access/do much with a suppressed constraint
		If oConst.Suppressed Then Continue For
		Dim oOcc1 As ComponentOccurrence = oConst.OccurrenceOne
		Dim oOcc2 As ComponentOccurrence = oConst.OccurrenceTwo
		Dim oEnt1 As Object = oConst.EntityOne
		Dim oEnt2 As Object = oConst.EntityTwo
		Dim oGeom1 As Object = oConst.GeometryOne
		Dim oGeom2 As Object = oConst.GeometryTwo
		'some types of constraints do not return a parameter, so below may = Nothing
		Dim oParam As Inventor.Parameter = GetParamFromConstraint(oConst)
		Dim oParamName As String = ""
		Dim oParamExp As String = ""
		If oParam IsNot Nothing Then
			oParamName = oParam.Name
			oParamExp = oParam.Expression
		Dim oReport As String = "Constraint Name:  " & oConst.Name
		oReport = oReport & vbCrLf & "Constraint Type:  " & TypeName(oConst)
		oReport = oReport & vbCrLf & "Component 1 Name:  " & oOcc1.Name
		oReport = oReport & vbCrLf & "Component 2 Name:  " & oOcc2.Name
		oReport = oReport & vbCrLf & "Entity 1 Type:  " & TypeName(oEnt1)
		oReport = oReport & vbCrLf & "Entity 2 Type:  " & TypeName(oEnt2)
		oReport = oReport & vbCrLf & "Geometry 1 Type:  " & TypeName(oGeom1)
		oReport = oReport & vbCrLf & "Geometry 2 Type:  " & TypeName(oGeom2)
		oReport = oReport & vbCrLf & "Controlling Parameter Name:  " & oParamName
		oReport = oReport & vbCrLf & "Controlling Parameter Expression:  " & oParamExp
		MsgBox(oReport, vbInformation, "Constraint Information")
	Next
End Sub
Function GetParamFromConstraint(oConst As AssemblyConstraint) As Inventor.Parameter
	Dim oParam As Inventor.Parameter = Nothing
	If TypeOf oConst Is AngleConstraint Then
		Dim oAngleConstraint As AngleConstraint = oConst
		oParam = oAngleConstraint.Angle
	ElseIf TypeOf oConst Is FlushConstraint Then
		Dim oFlushConstraint As FlushConstraint = oConst
		oParam = oFlushConstraint.Offset
	ElseIf TypeOf oConst Is InsertConstraint Then
		Dim oInsertConstraint As InsertConstraint = oConst
		oParam = oInsertConstraint.Distance
	ElseIf TypeOf oConst Is MateConstraint Then
		Dim oMateConstraint As MateConstraint = oConst
		oParam = oMateConstraint.Offset
	ElseIf TypeOf oConst Is RotateRotateConstraint Then
		Dim oRotateRotateConstraint As RotateRotateConstraint = oConst
		oParam = oRotateRotateConstraint.Ratio
	ElseIf TypeOf oConst Is RotateTranslateConstraint Then
		Dim oRotateTranslateConstraint As RotateTranslateConstraint = oConst
		oParam = oRotateTranslateConstraint.Distance
	ElseIf TypeOf oConst Is AssemblySymmetryConstraint Then
		Dim oAssemblySymmetryConstraint As AssemblySymmetryConstraint = oConst
		'there is no Parameter involved with this type of constraint
	ElseIf TypeOf oConst Is TangentConstraint Then
		Dim oTangentConstraint As TangentConstraint = oConst
		oParam = oTangentConstraint.Offset
	ElseIf TypeOf oConst Is TransitionalConstraint Then
		Dim oTransitionalConstraint As TransitionalConstraint = oConst
	Return oParam
End Function
C_Haines_ENG
Highlighting items can have quite an impact on performance, I cant image what flashing would do. The timing required to do flashing is also not well implemented in iLogic, so that may not be the route you would want to do.
However, you could highlight said entities in different colors.
_dscholtes_
I agree with @C_Haines_ENG, discard the flashing and use highlighting instead. Flashing will probably annoy the users very quickly.
To get text in the status bar, you can use this:
ThisApplication.StatusBarText = ""
Please note that as soon as you start moving the mouse over GUI elements, this text will be replaced with the element's hoover text.
