issue with iProperties mass not always updating properly
montylowe
Message 1 of 9
montylowe
I'm having issues with the mass of my parts not updating after I change material via ilogic code. It is acting like the mass is is an override. If I delete the mass manually and update it then become the correct mass. The code I am using is very basic. Any help would be greatly excepted......
Monty
Select Case HDRMATL
Case = 1
iProperties.Material = "SA516-70"
Case = 2
iProperties.Material = "SA516-70N"
Case = 3
iProperties.Material = "SA240-304"
Case = 4
iProperties.Material = "SA240-304L"
Case = 5
iProperties.Material = "SA240-316"
Case = 6
iProperties.Material = "SA240-316L"
Case = 7
iProperties.Material = "SA240-S31803"
Case = 8
iProperties.Material = "SA240-S32750"
Case = 9
iProperties.Material = "SB424-N08825"
Case = 10
iProperties.Material = "SA537-CL1"
Case = 11
iProperties.Material = "SA387-11"
End Select
Replies (8)
Message 2 of 9
MjDeck
You don't have another rule that is setting the mass?
If there is an override, you can remove it in your rule.  Add this to the end of the rule:
iProperties.Mass = -1  ' remove the override
InventorVb.DocumentUpdate()
mass = iProperties.Mass  ' recalculate the mass
Mike Deck
Software Developer
Autodesk, Inc.
Message 3 of 9
montylowe
Thanks Mike
Works great
Message 4 of 9
montylowe
Mike having an issue with the mass updating now all values are N/A
Message 5 of 9
MjDeck
The values are N/A when you open the iProperties dialog, right?  I think that's normal behavior.  The mass isn't calculated until it's requested.   Can you provide more details and maybe post a part?
Mike Deck
Software Developer
Autodesk, Inc.
Message 6 of 9
montylowe
Can you request it to be calculated per ilogic code?
Message 7 of 9
MjDeck
Yes, you can recalculate the mass using the code that I posted above:
But if you put this in a rule, the question then is: how do I make sure this rule gets fired?  Do you really need the mass to be always up-to-date?   How do you use the mass?
On the Tools -> Application Options dialog, on the General tab, there is an option Update physical properties on save.
Mike Deck
Software Developer
Autodesk, Inc.
Message 8 of 9
montylowe
Spoiler
It is part of a BOM rule the sets custom var's to populate the BOM structure. I am contorling the rule with Event Triggers.
Message 9 of 9
MjDeck
If you are modifying Inventor parameters in the same rule, you should add another statement:
RuleParametersOutput()
Mike Deck
Software Developer
Autodesk, Inc.
